91camaro_rs Member
![](images/avatars/16244201154a82fd8aac78b.jpg)
Posted: Sat Oct 20, 2012 2:05 pm Post subject: no 3rd brake light |
Ok so when i did the 9bolt swap i put in the new prop valve and i had to unplug the tan wire now i have no third brake light.... _________________
Posted: Sat Oct 20, 2012 2:09 pm Post subject: |
That's a neat trick considering that all the wire does is turn the brake warning light on in case of low pressure.
You must have a smart-ass flea ghost. ![Shocked](images/smiles/icon_eek.gif) |
91camaro_rs Member
Posted: Sat Oct 20, 2012 3:44 pm Post subject: |
Well i replaced the bulb. So ill make sure Im getting 12v at the bulb then check fuses and brake switch.. _________________
![](images/avatars/1674366422470d93dc81544.jpg)
Posted: Sat Oct 20, 2012 6:00 pm Post subject: |
The contacts in the 91-92 style center brake light get brittle pretty easily. Even though it's not on a long time, the bulb generates quite a lot of heat, sometimes enough to melt the lens, I've got one sitting around that has a hole melted in it. _________________ 92 Camaro
![](http://www.uzzisoft.com/randomsigscript/alhasse.jpeg) |
Albertallen New Member
Posted: Thu Dec 20, 2012 8:05 pm Post subject: Re: no 3rd brake light |
91camaro_rs wrote: | Ok so when i did the 9bolt swap i put in the new prop valve and i had to unplug the tan wire now i have led bulb no third brake light.... |
Have you checked the fuse it might have stopped working
91camaro_rs Member
Posted: Thu Dec 20, 2012 8:18 pm Post subject: |
3156 bulbs only work one direction...i had it backwards... _________________
Posted: Thu Dec 20, 2012 8:27 pm Post subject: |
![Smack!](images/smiles/slap.gif) _________________ A redline a day keeps the carbon away! |
