Piss Poor Planning Produces... A Running Banana?
PostPosted: Sat Aug 11, 2012 5:58 pm    Post subject: Piss Poor Planning Produces... A Running Banana? Reply with quote
Aaron is always losing his tools.
Tools were acquired and put to use.
Functional. For now.
I bet you can see where this is going...
Yup. Click it fool.
Anyway, that was our day. More fun tomorrow.
PostPosted: Sat Aug 11, 2012 6:58 pm    Post subject: Reply with quote
Is the turbo on it yet?
I feel as though I am missing some beer drinking time....
PostPosted: Sat Aug 11, 2012 7:23 pm    Post subject: Reply with quote
Can't have a turbo on there without a crossover and a cold side. Apparently someone hasn't built those yet. Very Happy It is open headers for now.
Beers are in the process of being dispatched at a prodigious rate indeed.
Keep in mind that the brody video is at about 50% throttle, we don't have a functional throttle cable setup yet so it is pretty rigged right now. We can only hit 53% throttle with the pedal on the floor. That problem is on the docket to be fixed tomorrow.
Some idiot put a transistor on backwards on the MegaSquirt board (wonder who that could be? Razz) and it was causing the fuel pump to run all the time. After that was ID'ed and fixed, we had to play with fuel and IAC tuning to get it to start and run, but we're doing pretty good so far as you can see. We don't even have a wideband on there yet, so it's all tuning by ear for now.
PostPosted: Sat Aug 11, 2012 9:00 pm    Post subject: Reply with quote
Damn, I hung out in North Tacoma this morning. I should've realized bananaananaa work would have been going down and texted you guys.
Nice job!
PostPosted: Sun Aug 12, 2012 11:53 am    Post subject: Reply with quote
Woot! She lives!
Way cool gentlemen.
PostPosted: Sun Aug 12, 2012 8:04 pm    Post subject: Reply with quote
It's true, kids. The car is totally running a driving. After rolling it around the neighborhood a bit yesterday Gabe and I took it about half a mile up the road before the exhaust pumping into the cab had annoyed me enough to turn around.
Some thoughts:
If you have a smoke detector in your shop you should take the battery out before you redline a motor with open headers inside. Cool
No exhaust means no wideband and so no ability for the ECM to target and AFR. Gabe was manning the laptop and fueling based off of the MAP sensor alone. This caused some tip-in issues, and it ran way rich with any amount of throttle. This was especially bad because with no HVAC covering the holes in the firewall Gabe and I were being pummeled by hot blinding exhaust smoke as we drove. Rolling Eyes Laughing
As such an HVAC blockoff plate has moved way up on the priority list.
The serpentine belt keeps jumping off the back of the alternator pulley (til it runs into the alternator case) with any RPM. I am not certain if this is the fault of the alternator, the tensioner/idler pulley, or maybe even the water pump. All are unknown units.
The start and die immediately issue that I was having was caused by the IAC acting retarded. With enough pedal I was able to keep it running but by the end of the day Gabe had mostly tuned that out so that it will start and stay running without pedaling now.
The engine free-revs to redline great. I would wager it's probably the fastest-revving motor I have ever had. Not sure how much of that is the aluminum flywheel on it, but speaking of that...
The Spec stage 3 is reasonable on the street. I was worried it would be aggressive or chatter because it is kinda hammered but it works fine.
Fourth-gen throttle cable with a third-gen firewall connector and a new swage on the cable seems to work pretty well. I cut the cable a bit short so the throttle pedal is higher than normal, but whatever.
Overall I am very pleased. There were a lot of questions on this build but for the most part it went great.
PostPosted: Sun Aug 12, 2012 8:21 pm    Post subject: Reply with quote
Awesome! Cool to see the Banana getting closer to running under boost! Dying to see this thing completed! Cool
PostPosted: Sun Aug 12, 2012 9:11 pm    Post subject: Reply with quote
Nice progress! Looking forward to when it's complete. Smile
PostPosted: Mon Aug 13, 2012 7:56 am    Post subject: Reply with quote
Nice Rat Fink shifter. Laughing
Are you ready for the cross over then? Get that intercooler mounted and we can spend a day and mock up all the good pipes :O)
PostPosted: Mon Aug 13, 2012 8:23 am    Post subject: Reply with quote
Yeah, that shifter sucks ass. Rolling Eyes The nylon bushing in the transmission is shot so it's super sloppy as well as being too long.
Intercooler is already mounted! You can get a good look at it when I'm backing out of the driveway in that video. Very Happy
PostPosted: Mon Aug 13, 2012 11:28 am    Post subject: Reply with quote
eXCELLENT. You get pipage for the CAC system?
PostPosted: Mon Aug 13, 2012 12:03 pm    Post subject: Reply with quote
No pipe yet. You got a PM though.
PostPosted: Sun Aug 19, 2012 8:48 pm    Post subject: Reply with quote
Who got creative with the Sharpie and wrote "the Great yellow hope" on the Driver's B-pillar?
PostPosted: Sun Aug 19, 2012 8:52 pm    Post subject: Reply with quote
I'm outta here
PostPosted: Mon Aug 20, 2012 7:21 am    Post subject: Reply with quote
http://www.thegearbox.org/catalog/item/3819132/7086766.htm
Best damn $22 I ever spent. It's so worth it if you're all about the little details that help your driving experience. Very Happy
PostPosted: Mon Aug 20, 2012 7:11 pm    Post subject: Reply with quote
Yup. I already have that exact page bookmarked.
On a related topic: does anyone know if Pro5.0 is still in business? Their website has been down for awhile and places seem to be low on stock of their shifters.
PostPosted: Wed Aug 22, 2012 4:39 pm    Post subject: Reply with quote
So how much of the interior is actually going back in?
And when do we get to see some performance numbers? Very Happy
PostPosted: Wed Aug 22, 2012 5:06 pm    Post subject: Reply with quote
I will have to fab up some sort of dashboard; probably aluminum painted or powdercoated flat black.
If I like the seats (and I think I do Wink) I will lighten them and have them recovered.
I have noticed a glare problem with the white floorpan reflecting on the inside of the windshield. If the black dashboard doesn't resolve that then I will look at some lightweight marine carpet for the front of the pan.
Heck if I know. Laughing
PostPosted: Wed Aug 22, 2012 5:11 pm    Post subject: Reply with quote
Rhinoline that shizzle.
PostPosted: Wed Aug 22, 2012 5:14 pm    Post subject: Reply with quote
No no, this is weight reduction project, Paul. Wink
