jchaussee Member
Posted: Sat Aug 11, 2012 5:30 pm Post subject: 99 f350 ac problems |
| So ac is working intermittently, so soon my reading I learned that the air gap on clutch housing grows over time which causes clutch to not engage. It says gap should be .020 and mine is .035. So it says I can remove shims to shrink it down. Problem is I can't get bolt of because it spins. So any trick to accomplishing this. |
jchaussee Member
Posted: Sat Aug 11, 2012 5:46 pm Post subject: |
| So I got it off. So it looks like what they call a shim is just a small washer.? So in order to shrink air gap coildnt I just use a thinner washer? |
Posted: Sat Aug 11, 2012 5:55 pm Post subject: |
Makes sense to me? _________________
jchaussee Member
Posted: Sat Aug 11, 2012 6:35 pm Post subject: |
| I have to remove .015 of and inch. Think sandpaper would do it. My issue is I am in Yakima and they are limited on their autoparts. Can't find the shim kit anywhere. |
Posted: Sat Aug 11, 2012 6:55 pm Post subject: |
I've never shimmed a compressor clutch.
Just sayin. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Sat Aug 11, 2012 7:10 pm Post subject: |
| They come with shims factory, but over time, at least from what I am reading the gap gets wider and that causes the clutch not to engage. At least from whatvi am reading |
jchaussee Member
Posted: Sat Aug 11, 2012 7:30 pm Post subject: |
| Really its just a washer, but it is going to take forever and a day to sand it down |
Posted: Sun Aug 12, 2012 4:44 pm Post subject: |
Tacoma Screw Yakima
711 East R Street
Yakima, WA 98901
Phone (509) 248-0711
Fax (509) 249-1711
Hours: Monday - Friday
7:00 am - 5:00 pm PST |
Posted: Sun Aug 12, 2012 5:05 pm Post subject: |
Yakima is quite a ways from Renton.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Aug 12, 2012 5:11 pm Post subject: |
| Alphius wrote: | Yakima is quite a ways from Renton.  |
| jchaussee wrote: | | I am in Yakima and they are limited on their autoparts. |
jchaussee Member
Posted: Sun Aug 12, 2012 5:31 pm Post subject: |
| I found some at home depot and filed down. Works like a champ now. |
Posted: Sun Aug 12, 2012 7:28 pm Post subject: |
I guess that teaches me to pay attention.
In my defense, we were about a sixpack in when I read the original post, eh Aaron?  _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Aug 12, 2012 8:05 pm Post subject: |
Four or five at that point. At six cans started getting throw into the yard.  |
Posted: Sun Aug 12, 2012 8:27 pm Post subject: |
| aaron_sK wrote: | Tacoma Screw Yakima
711 East R Street
Yakima, WA 98901
Fax (509) 249-1711
Seems like they should call it Yakima Screw.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Aug 12, 2012 8:38 pm Post subject: |
You'll see Tacoma Screw stores from Oregon to Idaho. All with the same name.  |
Posted: Sun Aug 12, 2012 10:24 pm Post subject: |
I know.  |
