jchaussee Member
Posted: Thu Aug 02, 2012 5:12 pm Post subject: grabbing a posi disc reat today |
| Still in car. I currently have drums. From a 88 ws6. What all should I grab with it |
Posted: Thu Aug 02, 2012 6:42 pm Post subject: |
E-brake cables.
Softline from axle to chassis so you can match up the threads.
If you are working by yourself the easiest way IMHO is to leave the tires and torque arm off and get the tail of the car up high. |
jchaussee Member
Posted: Thu Aug 02, 2012 6:49 pm Post subject: |
| He said he will help. Where do I put jack stands and do I need prop valve? |
Posted: Thu Aug 02, 2012 6:57 pm Post subject: |
You do need the prop valve.
Jack stands go under the chassis right in front of the low control arms.
Al took some pictures of me dropping the axle on his car in this thread:
http://cascadecrew.org/phpBB2/viewtopic.php?t=9160
Does this guy have air? |
jchaussee Member
Posted: Thu Aug 02, 2012 7:33 pm Post subject: |
| I don't know if he has air, but I do have an electric impact that may come on handy |
jchaussee Member
Posted: Sat Aug 04, 2012 5:16 pm Post subject: |
| So anyways got the gut to throw in lines, prop valve and ebrake cables for 100 for all. But it has 2.77 gears. , so question is cam that be remedied easily and half way inexpensively? |
Posted: Sat Aug 04, 2012 5:28 pm Post subject: |
| If this is a 9bolt then NO. |
Posted: Sat Aug 04, 2012 6:03 pm Post subject: |
Bastard child.
Only 2-series carrier for that axle. |
jchaussee Member
Posted: Sat Aug 04, 2012 6:06 pm Post subject: |
| Is it even worth doing swap then now.? It's still a posi disc for 100: instead of my dum non posi, but I did like my 3.23 gears |
Posted: Sat Aug 04, 2012 6:09 pm Post subject: |
The rear end is tough as hell. It's the good stuff.. BUT that gearing sucks and parts are a bitch to get besides costing $$$
You'll notice a definate performance drop. I went from 2.73 to 3.23 and the performance increase was night/day. So going the other way would suck. |
jchaussee Member
Posted: Sat Aug 04, 2012 6:10 pm Post subject: |
| Or would skylers 10 bolt 3.23 posi drum rear be better. |
Posted: Sat Aug 04, 2012 6:17 pm Post subject: |
If all you want is posi.
10 bolt will most likely hold up fine for most people on here.
If you want to upgrade to posi and discs... wait. |
Posted: Sun Aug 05, 2012 11:41 am Post subject: |
Going with Skyler's diff would seem way easier to swap in and you'd have the better gear ratio.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Aug 05, 2012 11:49 am Post subject: |
He said he allready has 3.23. So unless there's something wrong with his rear all he gains is the posi.
Not that I want to kill Skylers sale. 3.23 posi drum is what I run and I like it. |
jchaussee Member
Posted: Sun Aug 05, 2012 12:42 pm Post subject: |
| Can't get skyler to respond back, so not realyy possible to kill his sale because hes doing it already. |
