Aggressive Fan
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Sun Jun 10, 2012 7:32 pm    Post subject: Aggressive Fan Reply with quote
Wants to go go go before decent op temp. Any ideas?
Makes the car run colder than needed
PostPosted: Sun Jun 10, 2012 7:52 pm    Post subject: Reply with quote
Switch in the head going bad? Mine was on almost constantly before I replaced the switch.
PostPosted: Sun Jun 10, 2012 8:04 pm    Post subject: Reply with quote
LB9 was ECM controlled as I remember. So I would guess bad coolant temp sensor.
If you can datalog (or know someone who can) you would be able to confirm this before purchasing parts.
PostPosted: Sun Jun 10, 2012 8:41 pm    Post subject: Reply with quote
Dont have the AC or defrost on?
Also car shouldnt run below thermostat temp, even if the fan never shuts off.
PostPosted: Mon Jun 11, 2012 4:59 am    Post subject: Reply with quote
Idk, about the single fan setup but the dual fan set up on LB9's have a temp switch in the head for fan #1, and cooling fan #2 is ECM controlled and activated by the A/C switch.
Oh, and here's the stock temperature perameters in case anyone was curious.
Cooling fan #1 enabled at 107̊C (226̊F)
Cooling fan #1 off at 104.7̊C (220.5̊F)
Cooling fan #2 enabled at 115.2̊C (239.5̊F)
Cooling fan #2 off at 110̊C (230̊F)
Cooling fan duty cycle at 100% at 80̊C (176̊F)
PostPosted: Mon Jun 11, 2012 8:11 am    Post subject: Reply with quote
85 TPI single fan ecm controlled.
85 T/A WS6
PostPosted: Mon Jun 11, 2012 2:31 pm    Post subject: Reply with quote
AC off. Unplugged battery to try to reset, maybe I didnt leave it dead long enough...what is proper time to kill ECM memory?
I have a 170 T-Stat if I recall....
Put the second new fuel pump in, seems to work so far, was a fun weekend Sad
PostPosted: Mon Jun 11, 2012 3:15 pm    Post subject: Reply with quote
AFAIK there is nothing that the ECM learns that affects the fan.
PostPosted: Mon Jun 11, 2012 4:12 pm    Post subject: Reply with quote
Strictly an on/off parameter threshold.
85 T/A WS6
PostPosted: Tue Jun 12, 2012 6:28 am    Post subject: Reply with quote
I have a new Hypertech switch, maybe Ill put that in, no access to data logger.
If my ECM is going out, and I replaced 2 fuel pumps as a result, I'm going to the moon. Embarassed
PostPosted: Tue Jun 12, 2012 8:07 am    Post subject: Reply with quote
Ecm triggers a relay for the pump, not the pump itself.
