cameron7710 Member
Posted: Wed Apr 11, 2012 3:44 pm Post subject: non thirdgen problem |
i just got a van and now it wont start. first off its 93 chevy cargo van with 305 tbi and had been siting for about a year. but i picked it up in shelton on friday and it drove the 110 miles back fine. then i flushed the cooling system and changed the themostate yesterday and took it for a drive and still went great but the next time i tryed to start it the starter dose nothing tryed a differnt battery and still nothing. just wondering where the best place to start trouble shooting is cause i have no idea _________________
flea Member
Posted: Wed Apr 11, 2012 3:53 pm Post subject: |
Whack it with a hammer. _________________ Killing mailboxes since 2009 |
cameron7710 Member
Posted: Wed Apr 11, 2012 4:07 pm Post subject: |
hmm well didnt need to wack it with a hammer but i just went out to check some things and it fired right up so i dont really know what the problem was i just hope it dosent do it again. im sure it probley will tho i dont think problem like that will just go away _________________
Posted: Wed Apr 11, 2012 4:21 pm Post subject: |
There's been a few posts on here about starter problems.
First thing to do when it doesn't crank, is get a test light and see if the solenoid wire lights up with the key in the "start" position. If it does, it needs a starter or your heavy battery cables are fubar. If not you've got an ignition switch/wiring issue. _________________ A redline a day keeps the carbon away! |
flea Member
Posted: Wed Apr 11, 2012 6:09 pm Post subject: |
Posted: Wed Apr 11, 2012 6:48 pm Post subject: |
Don't discount flea's terrible advice. That's the redneck way of freeing up a stuck solenoid or bendix
Paul's thoughtful advice is probably a better bet, however.  |
flea Member
Posted: Wed Apr 11, 2012 7:01 pm Post subject: |
Terrible??
Whatchu talkin' bout. _________________ Killing mailboxes since 2009 |
cameron7710 Member
Posted: Thu Apr 12, 2012 6:06 pm Post subject: |
well sure enough the problems back this time it was cranking tho and just stoped right before the engine fired. i thought this was due to a bad battery connection because the top post to side post battery adapter where striped out so i replaced thoses with new ones and checked the battery cables for corrosion or breaks and found nothing and it still wont crank and im pretty sure the ignition switch is fine cause all the dummy lights and the radio go off when u try to start it . so im pretty sure at this point i need a new starter or solenoid. i just need to find my multi-meter so i can check everything for sure.
and yes flea i did resort to wacking it with a hammer still nothing  _________________
Posted: Thu Apr 12, 2012 6:42 pm Post subject: |
Do what I suggested first.
Also do what flea said. Have someone turn it to START and hold it. Tap the starter with a hammer. If it fires right off you need a starter.
Your diagnosis of the ignition switch doesn't tell you anything. Just because the other stuff goes off, doesn't mean it's engaging the start circuit. _________________ A redline a day keeps the carbon away! |
Posted: Thu Apr 12, 2012 7:54 pm Post subject: |
| Isn't anybody curious why he wanted a cargo van? |
Posted: Thu Apr 12, 2012 8:05 pm Post subject: |
| QwkTrip wrote: | | Isn't anybody curious why he wanted a cargo van? |
Free Candy? |
Posted: Thu Apr 12, 2012 8:25 pm Post subject: |
The logical argument would be that he wants to move things, but he says it has a 305 so that can't be it...
Maybe you have a point, Jon. |
flea Member
Posted: Thu Apr 12, 2012 8:26 pm Post subject: |
I assume he wanted something to whack with a hammer. _________________ Killing mailboxes since 2009 |
cameron7710 Member
Posted: Sat Apr 14, 2012 6:36 pm Post subject: |
well i was never able to find my tester so i said screw it and just poped the starter off and had it tested at the part store. and it check out fine so i put it back in and still nothing so i took cables off the solenoid and sanded the shizzle out of all of them and it fires up great now
| QwkTrip wrote: | | Isn't anybody curious why he wanted a cargo van? | well u all are right. needed a van for my dads work and it was free it was my grandpas befor he passed last year. and i never wanted to hit the camaro with a hammer so i needed somthing  _________________
Twigger New Member
Posted: Tue Apr 17, 2012 11:47 pm Post subject: |
| Glad to hear you fixed you problem but just to chime in, the starter testers at the parts store are pretty much worthless. I would say 4 out of 5 bad starters on those machines will test good. It's a simple spin test with no load so you really have to use your ear to listen and see if it sounds bad. When in doubt have the guy throw a new one on there to compare how it sounds. |
