2ea 10-bolt
PostPosted: Sun Apr 08, 2012 7:01 pm    Post subject: 2ea 10-bolt Reply with quote
I have two axles I need to find homes for. Both axles are in Poulsbo. Make me an offer or they go to the scrap yard. I'm sure a delivery can be worked out.
Axle #1
10-bolt, 4.11 gears, tight auburn posi, disk brake flanges, 94 camaro aluminum caliper PBR brakes and 11.5" rotors.
Axle #2
10-bolt, 3.42 gears, really tight Lincoln posi, disk brake flanges, no calipers or rotors.
jchaussee
PostPosted: Sun Apr 08, 2012 7:31 pm    Post subject: Reply with quote
I am perhaps interested in number 2. Is it complete and halfway ready to go short of the brake stuff?
PostPosted: Sun Apr 08, 2012 7:32 pm    Post subject: Reply with quote
I kind of want the steep gear'd one...
BluFbdy
PostPosted: Mon Apr 09, 2012 9:52 am    Post subject: Reply with quote
Holy crap a 4.11? I want it for the posi and brakes but I kinda like my so so gas mileage lol if nobody makes an offer think you could throw the disk brakes on to the milder geared one?
PostPosted: Mon Apr 09, 2012 6:39 pm    Post subject: Reply with quote
#1 is setup with 4.11's, 2 series posi with a 3 series adapter. It would be great if you tossed a 2 series ring and pinion in. The diff itself works great. That high of a rear isn't all that bad. I think I was turning 2800 rpm with a 700r4.
I was mistaken, the #2 option is setup with the brakes. I was going to toss it behind the big block to see if I could break it.
Both axles have the tubes welded to the center. Also, both axles have the relocation brackets welded on them for the lower control arm.
1987_sportcoupe
1987 Chevrolet Camaro
PostPosted: Mon Apr 09, 2012 7:11 pm    Post subject: Reply with quote
I'd be interested in the second one if the price is right. What were you thinking?
PostPosted: Mon Apr 09, 2012 8:28 pm    Post subject: Reply with quote
I'm interested in the second one, 3.42 gears would suite autocross better than my 3.73's. Also I need relocation brackets.
redlava
PostPosted: Tue Apr 10, 2012 7:36 am    Post subject: Reply with quote
Is #1 from a 4th gen or a 3rd gen?
PostPosted: Tue Apr 10, 2012 1:27 pm    Post subject: Reply with quote
I will take one with disc brakes off your hands. I just picked up another Posi rear that has drum flanges.. Sad i did not realize until i put it on that the flanges are different.
What would you want for one?
PostPosted: Tue Apr 10, 2012 10:02 pm    Post subject: Reply with quote
sold.
PostPosted: Tue Apr 10, 2012 10:19 pm    Post subject: Reply with quote
Well damn. Laughing
PostPosted: Wed Apr 11, 2012 7:22 am    Post subject: Reply with quote
Which one?
PostPosted: Wed Apr 11, 2012 10:05 pm    Post subject: Reply with quote
Both. Wish I had more. Seems to be a need for setup axles.
