RK82 Member
1982 Pontiac Trans Am
Posted: Mon Oct 10, 2011 4:40 pm Post subject: Opps!!! |
backing off the hoist yesterday the corner of the ramp just nicked my muffler, oh well now I have a excuse to build a new exhaust system.
Posted: Mon Oct 10, 2011 7:52 pm Post subject: |
This time you can use a good muffler, not a noisy chambered one.  |
Posted: Mon Oct 10, 2011 8:43 pm Post subject: |
ouch is right... _________________
RK82 Member
Posted: Tue Oct 11, 2011 10:53 am Post subject: |
| I think I might try a moroso spiral flow muffler |
Posted: Tue Oct 11, 2011 11:53 am Post subject: |
Not sure what you are going for sound wise but heads up that there is not much 'muffling' going on with a Moroso spiral flow.
-Schultzy |
Posted: Tue Oct 11, 2011 12:21 pm Post subject: |
| Schultzy89GTA wrote: | Not sure what you are going for sound wise but heads up that there is not much 'muffling' going on with a Moroso spiral flow.
-Schultzy |
As in NONE. _________________ A redline a day keeps the carbon away! |
Posted: Tue Oct 11, 2011 4:46 pm Post subject: |
| As in following about 100yds back not only did Schultz drowned out my hooker, but vibrated my floorboards enough to give a nice foot massage. |
RK82 Member
Posted: Wed Oct 12, 2011 12:23 pm Post subject: |
-Schultzy |
other forums say there about 4-5 decibels quieter than open headers.
I want it loud the last exhaust was way to quiet |
Posted: Wed Oct 12, 2011 2:46 pm Post subject: |
| Why even run a muffler then? I can still talk on my phone with the 454 on straight pipe. Until i start it, then forget it. Jeremy clarkson calls it a loud pedal for a reason. Lol. |
Posted: Wed Oct 12, 2011 5:05 pm Post subject: |
No worries man, like I said, not sure what you are looking for. Was just a heads up.
Sounds like it would be a good choice for you based on what you want.
When I ran them I was running dual 3" exhaust on a fairly healthy 383.
-Schultzy |
RK82 Member
Posted: Wed Oct 12, 2011 7:53 pm Post subject: |
| Schultzy89GTA wrote: | No worries man, like I said, not sure what you are looking for. Was just a heads up.
-Schultzy |
didn't mean come off as a dick in that last post, I appreciate the heads up  _________________
RK82 Member
Posted: Wed Oct 12, 2011 7:57 pm Post subject: |
| blue89 wrote: | | Why even run a muffler then? I can still talk on my phone with the 454 on straight pipe. Until i start it, then forget it. Jeremy clarkson calls it a loud pedal for a reason. Lol. |
mostly sound, I drove it for a few weeks straight piped with no muffler, it sounded like demo derby car  _________________
Posted: Wed Oct 12, 2011 8:51 pm Post subject: |
| RK82 wrote: |
didn't mean come off as a dick in that last post, I appreciate the heads up  |
It's all good man. You want it loud these should help. They have kind of a unique sound too and not very spendy.
-Schultzy |
RK82 Member
Posted: Thu Mar 08, 2012 7:35 pm Post subject: |
so since I can't decide on what I what to do for exhaust yet, I figured I should try patch my flowmaster and move it to the stock location
started with this
I didn't spend a whole lot of time on it cuz the rest of the exhaust is quite the hack job
First time welding with flux core wire so the welds are kinda bubble gummy |
Posted: Thu Mar 08, 2012 9:00 pm Post subject: |
I hope the fuel line isn't as close to the exhaust as it appears in that pic!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu Mar 08, 2012 9:06 pm Post subject: |
| Factory routing for a carb car IIRC. |
Posted: Thu Mar 08, 2012 11:37 pm Post subject: |
| aaron_sK wrote: | | Factory routing for a carb car IIRC. |
True. Factory routing. But the factory wasn't a braided AN line.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Fri Mar 09, 2012 10:27 am Post subject: |
damn son, you need new tires bad! lol
Good work with the welding though!
RK82 Member
Posted: Fri Mar 09, 2012 10:53 am Post subject: |
| 83Z28BlackBetty wrote: | damn son, you need new tires bad! lol
~JAKE |
already done Nitto NT555Rs
Posted: Fri Mar 09, 2012 3:09 pm Post subject: |
| How is the sound difference from the cat position, to stock muff position? |
