Posted: Tue Feb 21, 2012 6:43 pm Post subject: |
They are now about level, maybe slightly lower on axle end now.
But up tell about 3mo ago, they were very much lower on the body end. |
Leejo2005 Member
Posted: Wed Feb 22, 2012 12:22 am Post subject: |
| I have the spohn torque arm and cross member as well. I don't have any issues with it hitting the floor, probably because my car sits pretty high. What is the pop coming from? I can hear mine do it occasionally when switching between accel and decel. I've put it on the lift and tugged and shook everything and can't find anything loose. |
Posted: Wed Feb 22, 2012 3:39 am Post subject: |
| The front joint where it meets the crossmember. You have the cross member "hoop" that the bolt goes thru. Then you have 2 flat plates that pivot on the ends of it. |
