turbo_jimi Member
Posted: Thu Feb 09, 2012 7:46 pm Post subject: Camaro Parts |
Here are some parts I have for sale:
Dash Pad-really nice except for 1 corner that I've started to repair
Lower Center Console with Grey Carpet- nice condition
3 styles of e-brake handles...leather (i believe), smooth plastic, and plastic with hand-grip shape. All nice.
Upper Center Console with Lid-small tear in lid mostly repaired and the bezel around the button is intact which is rare.
2 Timing Chain Covers-both have timing tabs; on attached, on bolt-on
2 Oil Pans
New Timing Chain with Gears-sitting in oil.
Rear Hatch Cover-that might be John's I don't remember.
2 sets of stock valve covers-- non-centerbolt style--one plain, one with ridges.
A/C parts: New Blower Fan, Compressor, Canister (aluminum)
Stock Rear Control Arms, Torque Arm, Driveshaft, Panhard Rod and eventually front and rear Z28 Sway Bars (unless better than Berli types)
Other odds and ends (smog pumps, engine parts, front air dams)...just ask.
Not for sale is John's spare TPI set-up...it might go in the Berli one day.
Make offer...I'd like space in my shed! _________________
Posted: Thu Feb 09, 2012 7:51 pm Post subject: |
I would like a front air dam for a GFX Camaro if you have one.
The Z28 bars are better than the Berli by a long shot. The Berlinettas did not come from the factory with a rear bar at all. |
turbo_jimi Member
Posted: Thu Feb 09, 2012 7:57 pm Post subject: |
| aaron_sK wrote: | I would like a front air dam for a GFX Camaro if you have one.
i'll leave both where the valve covers are...not sure which one is which.
guess i'll save the sway bars for john if he wants them. _________________
Posted: Thu Feb 09, 2012 8:01 pm Post subject: |
| Thanks, man! |
turbo_jimi Member
Posted: Thu Feb 09, 2012 8:03 pm Post subject: |
No problemo. There are out there. _________________
turbo_jimi Member
Posted: Thu Feb 09, 2012 8:04 pm Post subject: |
I also have 3 styles of e-brake handles...leather (i believe) smooth plastic, and plastic with hand-grip shape. I'll add to list. _________________
91camaro_rs Member
Posted: Thu Feb 09, 2012 11:37 pm Post subject: |
depending on my paycheck tomorrow i might want that leather handle if its in good shape _________________
Posted: Fri Feb 10, 2012 8:25 am Post subject: |
Don't sell my TPI!!! _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
turbo_jimi Member
Posted: Fri Feb 10, 2012 9:19 am Post subject: |
| RSFreak wrote: | | Don't sell my TPI!!! |
Don't worry...lol! _________________
turbo_jimi Member
Posted: Mon Feb 13, 2012 1:52 pm Post subject: |
| 91camaro_rs wrote: | | depending on my paycheck tomorrow i might want that leather handle if its in good shape |
I would say it's in good shape, but not perfect...a couple of cracks on the end and a little chip in the bottom. _________________
jchaussee Member
Posted: Mon Feb 13, 2012 2:12 pm Post subject: |
| If you have more then one air dam id be interested |
turbo_jimi Member
Posted: Mon Feb 13, 2012 2:23 pm Post subject: |
The one I have left is for a sport coupe. _________________
Posted: Mon Feb 13, 2012 8:05 pm Post subject: |
No it is not.
I do not know specifically what it is off of but I suspect it is from a brick-nose Trans Am.
The Sport Coupes did not get a divorced air dam like most other f-bodies. It was built into the lower half of the front bumper. |
turbo_jimi Member
Posted: Mon Feb 13, 2012 8:10 pm Post subject: |
you're right...I threw the berli one in the trash the day after we took it off John's car. might be for the TA then, but it's got 2 extra bolt holes to prevent it from being sucked into the intake.  _________________
jchaussee Member
Posted: Mon Feb 13, 2012 9:05 pm Post subject: |
| So will it go onto my Camaro. |
turbo_jimi Member
Posted: Fri Feb 17, 2012 10:07 am Post subject: |
| jchaussee wrote: | | So will it go onto my Camaro. |
not correctly. _________________
