   1989  Pontiac  Firebird
				 Posted: Mon Dec 19, 2011 9:15 am    Post subject: Proof that I am mentally unstable |
				| So, that used to be a perfectly good 4th gen harness.  Now I guess I should do the rest of the laundry so I have more room. |
   1991  Chevrolet  Camaro RS
				 Posted: Mon Dec 19, 2011 9:23 am    Post subject:  |
				Looks perfectly normal to me   _________________ 2008 GMC Z71
				 Posted: Mon Dec 19, 2011 10:23 am    Post subject:  |
				I love hacking and whacking on wiring harnesses. I've got a big one to do myself.
Atleast GM kept things engine related together.
Mazda on the otherhand completely integrated the engine and dash and chassis harnesses. Hell the igintion coils aren't even part of the engine harness!
You lucky bastid! _________________ A redline a day keeps the carbon away! |
				 Posted: Mon Dec 19, 2011 12:38 pm    Post subject:  |
				Now it is looking better!
So far I've had to cut only 4 wires at the Positive and Negative commons to lop off the rear O2 sensors.  Everything else is still in tact with a few connectors de-pinned to allow separate bundling of wires. |
   1986  Chevrolet  Camaro RS
				 Posted: Mon Dec 19, 2011 1:53 pm    Post subject:  |
				Not a half bad method!    _________________ A redline a day keeps the carbon away! |
				 Posted: Mon Dec 19, 2011 4:18 pm    Post subject:  |
				 	  | blue89 wrote: | 	 		  | Looks like you depinned the pcm connector, correct? I had good luck ordering pins from mouser or digikey for the sensors. |
Thanks.  I didn't damage anything.  Just stuff them back in when I'm ready.
 	  | Twilightoptics wrote: | 	 		  Not a half bad method!    |
Yep, just lay it down in the car one circuit at a time for a perfect fit.  The main reason I did it is because I need to lengthen the harness for placement of the PCM.  Still wondering best way to do that.  I'm leaning towards connectors rather than soldering because wire gets brittle after solder.
I've had a heck of a time finding a decent fuse block.  I finally talked to an engineer in my building that specializes in circuit protection and fuse blocks (yes, we have specialists for everything).  He had samples of a Bussman block that I liked.  I'll be ordering that soon but first I need to figure out how I want the buss bar configured. |
				 Posted: Mon Dec 19, 2011 5:09 pm    Post subject:  |
				Heat shrink butt connectors are awesome.
Just use the "uninsulated" bit of your crimpers. Heat the connector with a mini torch and you have a glued, sealed, excellent fit. We use them religiously at work and are warranty approved.
If you want to get hardcore with it, you can use regular heatsrink over the top. I'll snap a picture of the good ones. _________________ A redline a day keeps the carbon away! |
				 Posted: Mon Dec 19, 2011 5:14 pm    Post subject:  |
				Before and after heat. _________________ A redline a day keeps the carbon away! |
				 Posted: Mon Dec 19, 2011 5:39 pm    Post subject:  |
				| What do you know about the heat solder connectors?  The temperature rating can't be very high before solder reflow?  Maybe if the connections are nowhere near engine exhaust then it might be okay? |
				 Posted: Mon Dec 19, 2011 6:01 pm    Post subject:  |
				I figure it this way. If these crimp ones are good enough for heavy semi use, they'll outlast the car.
I did about 40 wires on an engine ecm about a year and a half ago. Local truck, we do their services. No issues on the wiring itself.
Solder has it's place, but I you're correct, they get brittle and if not done properly can cause issues later. Thats even more why I like these guys, stiff in the middle, and the heatshrink part gives it the flex and it's much thicker than your store bought heat shrink so the protection is better too. _________________ A redline a day keeps the carbon away! |
				 Posted: Mon Dec 19, 2011 7:52 pm    Post subject:  |
				 	  | Twilightoptics wrote: | 	 		  | Mazda on the otherhand completely integrated the engine and dash and chassis harnesses.  |
That must be why it takes as long to untangle a Mazda harness as it does to pull a Honda engine and trans.    |
				 Posted: Mon Dec 19, 2011 8:08 pm    Post subject:  |
				 	  | aaron_sK wrote: | 	 		   	  | Twilightoptics wrote: | 	 		  | Mazda on the otherhand completely integrated the engine and dash and chassis harnesses.  |
:nods: _________________ A redline a day keeps the carbon away! |
   1991  Pontiac  Trans Am
				 Posted: Mon Dec 19, 2011 9:03 pm    Post subject:  |
				 	  | Twilightoptics wrote: | 	 		  | Before and after heat. |
Those are what I used on my harness and it's going strong tens of thousands of miles later.   _________________
 	  | Quote: | 	 		  | Sometimes I actually think I'm slightly retarded in the mouth. |
				 Posted: Mon Dec 19, 2011 10:36 pm    Post subject:  |
				What I would really like to do is use new wire everywhere without any splices, but that kind of defeats the purpose of buying a 4th gen harness except to see how it is put together.
Speaking of which, I found a place that will build a new harness for about $450 with the PCM length to whatever you need.  That is darn reasonable!  And they use all new Delphi connectors and split loom.  Almost went that route except the fuse block was the cheap ugly kind without a proper B+ post and no internal buss bar, and I'd probably not be happy with where the wires are routed anyway. |
