1987_sportcoupe Member
1987 Chevrolet Camaro
Posted: Wed Nov 16, 2011 10:50 pm Post subject: My first build thread |
| Sooooooo I've decided to make a thread on my first engine build. I just recently bought a 350 out of a 70's blazer. the machine work was already done to the block (bored .30 over) and the heads were rebuilt. (Hasn't been fired since the machine work) Right now I'm saving up for another car so I can start tearing my camaro apart so this thread is going to start out kind of slow lol. Anyways I have almost the rest of the engine parts (minus carb, oi8l pan, and gaskets) but most of the stuff will be replaced for aftermarket parts. I'll post pics when i can figure out how to downsize the size of my photos haha. |
Posted: Wed Nov 16, 2011 11:03 pm Post subject: |
Piiiiicccttturrreeeessss.
Good start though. _________________
Posted: Wed Nov 16, 2011 11:07 pm Post subject: |
Use Photobucket. Automatically resizes pictures.
What heads on that motor? |
Posted: Thu Nov 17, 2011 10:33 am Post subject: |
| aaron_sK wrote: | | What heads on that motor? |
X2 |
Posted: Thu Nov 17, 2011 12:33 pm Post subject: |
Oh yeah! Bring on the pictures!
-jake _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Mon Dec 12, 2011 10:00 pm Post subject: |
| Pictures finally |
Posted: Mon Dec 12, 2011 10:01 pm Post subject: |
| more |
Posted: Mon Dec 12, 2011 10:31 pm Post subject: |
| heads, maybe you guys can help me identify them. I can post the casting numbers too |
Posted: Mon Dec 12, 2011 10:33 pm Post subject: |
| picked these up today brand new for $100 |
Posted: Tue Dec 13, 2011 4:10 am Post subject: |
Need casting numbers on the heads or at least close up pictures of all the numbers under the valve cover.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Dec 13, 2011 8:01 am Post subject: |
And clean up that garage. You're building a motor. It's "clean work." Cleanliness is truely Godliness when working with engine internals. _________________ A redline a day keeps the carbon away! |
Posted: Tue Dec 13, 2011 2:17 pm Post subject: |
| Casting numbers on heads is 3998993 underneath says F8 73 |
Posted: Tue Dec 13, 2011 2:55 pm Post subject: |
3998993 1968-79 350 1.94 / 1.5 CFM inl 150 / exh 91
3998993 1968-76 307 - 350 75cc chamber. Low performance cars & trucks
Looks like standard smog-era 350 heads with 75cc chambers and 1.94/1.5 valves. About the same as what I have on my motor for the next week or so. _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Dec 13, 2011 3:02 pm Post subject: |
| I figure ill use them until I have enough money to get aluminum ones bi just want to get the motor built and in the car. Heads aren't that hard to change once its in the car. |
Posted: Tue Dec 13, 2011 3:10 pm Post subject: |
| 1987_sportcoupe wrote: | | I figure ill use them until I have enough money to get aluminum ones bi just want to get the motor built and in the car. Heads aren't that hard to change once its in the car. |
Yeah, I'm doing a head swap soon in car.
You might be happy with the power from those heads. _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Dec 13, 2011 3:13 pm Post subject: |
| Yea but if I can get more I will haha |
Posted: Tue Dec 13, 2011 3:34 pm Post subject: |
Your best bet with those crappy heads is to run the .015 head gasket, and clean all the casting flash up on the ports. _________________ A redline a day keeps the carbon away! |
Posted: Tue Dec 13, 2011 5:23 pm Post subject: |
And if your pistons are flattop with valve relief you should end up with an acceptable compression ratio. Using a standard .041 gasket and stock dished pistons would give you something silly like 8:1.  _________________ 84 Camaro Z28 - LS1/T56
IROCDave Member
Posted: Fri Dec 16, 2011 4:30 pm Post subject: |
| I have a set of Trick Flow heads with 64cc chambers. They have about 10K miles on em, 500.00 and there yours. Send me a PM if your interested. |
Posted: Mon Jan 16, 2012 2:29 pm Post subject: |
| I've been lookingonto GM performance vortec heads. Any opinions on these? Anybody use them? |
