IROCDave Member
Posted: Sat Nov 05, 2011 3:22 pm Post subject: Problem with trunk lid pull down |
The tonneau cover release stopped working on the convertible last summer. I tracked the issue down to the safety switch mounted to the trunk lid pull down assembly. The switch is depressed when the pull down aassemby is down. GM did this so that the tonneau could not be released while the trunk lid is opened as they occupy the same space when opened.
The issue is that the white plastic guides on the pull down track are starting to fall apart. A peice broke off at the bottom of the drivers side track, the switch wasnt being fully depressed. I adjusted the switch so that it hits the end of the metal track, but I dont think the switch will last long with metal to plastic contact.
Anyone know of replacement guides? |
Posted: Sat Nov 05, 2011 3:58 pm Post subject: |
Well with a business name of "Top Down Solutions" I sure hope they would have a solution, it's kind of implied.  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
IROCDave Member
Posted: Sun Nov 06, 2011 5:27 pm Post subject: |
| Al, not sure if they are the same? According to posts on TGO they are. The guides on the convertible are white plastic, similar to the giudes in the link, but I think the old guides were one peice or one per side.The link shows 4 peices, 2 per side? |
