Head work
PostPosted: Tue Nov 01, 2011 11:13 pm    Post subject: Head work Reply with quote
Well the bird has started using some oil lately, Many of you may remember I swapped some Vortec heads on the L03 and stabbed in a cam with just over .500" lift. I jumped the gun on researching how much lift my heads could handle Embarassed and I think I have a spring retainer to valve guide clearance issue, squishing the valve seal and causing the oil burning problem. I did go ahead and do a compression check also and found the old 172K mile 305 has between 165-175PSI across all 8.
So I guess my question is, If I pull the heads, have the guides cut for more lift, and put some new seals on should that fix the oil burning problem? Or do I need something else, maybe new guides? Trying to get the car ready for dyno and back to daily driver status.
Thanks!
PostPosted: Wed Nov 02, 2011 2:21 am    Post subject: Reply with quote
News the guide bosses cut for sure and checked for that lift.
Machine shop will check guide condition while.in there.
Good.compression.... Doesnt tell you that much. Atleast do a leak down.
charlie6178
PostPosted: Wed Nov 02, 2011 11:08 am    Post subject: Reply with quote
the vortec heads generally don't wear guides too bad as a common issue. i build cylinder heads for a living lol yes the guides can me topped down .030" without an issue, and we do have smaller style seals to prevent retainer issues. it's not terribly time hard to top the guides, it's just time consuming.
1992 Camaro 1LE Z28
PostPosted: Wed Nov 02, 2011 11:11 am    Post subject: Reply with quote
shizzle I cut Vortec guides down WAY farther than 0.30".
Gotta remember, we don't know what his pushrod geometry is with a head swap and if the retainers are bottoming out, it could wear the guides.
charlie6178
PostPosted: Wed Nov 02, 2011 11:37 am    Post subject: Reply with quote
shizzle you CAN cut them down to the spring seat if you want to lol but id say leave as much material as possible up top. usually between .030"-ish and a shorter seal, it takes care of the issue.
1992 Camaro 1LE Z28
PostPosted: Wed Nov 02, 2011 4:50 pm    Post subject: Reply with quote
I usually cut alot of mine just so that I dont need to pull the heads for the next cam swap. Usually only leave enough to locate the spring and shims! lol When you only take 0.030 off you better have your calculations and measurements in order.
PostPosted: Thu Nov 03, 2011 11:12 am    Post subject: Reply with quote
I was thinking I'd atleast want them cut down enough that I could put some 1.6 rockers on if I wanted to later.
