Posted: Thu Oct 13, 2011 9:26 pm Post subject: Who is local and can datalog? |
I really regret selling all my Chebbie datalog stuff.
Car is running, I can come to you. I can bring beer or whatever. Friday and Sunday are good, Saturday is not. |
turbo_jimi Member
Posted: Thu Oct 13, 2011 9:29 pm Post subject: |
what are you programming? _________________
Posted: Thu Oct 13, 2011 9:33 pm Post subject: |
Nothing. I need to read not write.
Z24 is stalling when coming to a stop. Will not throw codes. I want to datalog it while it does it to see if anything goes out of whack immediately prior. |
Posted: Thu Oct 13, 2011 10:17 pm Post subject: |
I think I still have the obd1>serial cable at the tacoma house where alex is at. If you want to stop by I'm sure he'd let you dig through the garage shelves. You have a laptop? (if not I'm coming down sat night) _________________
Posted: Fri Oct 14, 2011 7:30 am Post subject: |
I have cable and laptop. If you come up here Friday evening at or after 6PM I will be here. Text me if you want, I will be at work.
EDIT: Scratch that, it looks like I'm leaving town right after work. I would help if I could, man. Then you could take the cable to John at some point, who still needs it. _________________ 84 Camaro Z28 - LS1/T56
Posted: Fri Oct 14, 2011 10:08 am Post subject: |
IAC. _________________ A redline a day keeps the carbon away! |
Posted: Fri Oct 14, 2011 11:14 am Post subject: |
So I umm... fixed it?
Here's the deal, clutch was shot and the car had a slight miss at idle. Installed new clutch and new plug wires (plugs had been done recently).
Immediately after I did that (like the first test drive) it started stalling at complete stops. Would not stall when cruising in neutral. Would not stall at every stop. Would often restart and stay running but sometimes would not idle at all. Sometimes had surging idle for a bit. Ran fantastic everywhere else.
Today I did the normal check of stuff (vacuum, loose wires, cleaned IAC, ect.). Went to check minimum air and found that the car would not idle with the IAC unplugged. Checked the throttle stop and the cap removed and screw backed almost all the way out.
With the IAC still unplugged I ran the stop screw back in till the car would idle (but still very low RPM). Plugged it back in, unhooked the battery and it has not stalled since.
I am unsure if that was the exact problem, or if I band-aided it. Also unsure if it was something I did that uncovered this problem. Maybe I unknowingly fixed a vacuum leak or something? |
Posted: Fri Oct 14, 2011 11:36 am Post subject: |
If the screw backed out, that'd do it. IAC can only allow so much air.... _________________ A redline a day keeps the carbon away! |
popballz Member
Posted: Fri Oct 14, 2011 2:05 pm Post subject: |
i got a brand new moates aldl to usb adapter. i work on sunday if you wanna stop by and check it out/borrow for a little bit. _________________ -Donald
Posted: Fri Oct 14, 2011 2:40 pm Post subject: |
Nice job Aaron. Good find.  _________________ 84 Camaro Z28 - LS1/T56
