BluFbdy Member
Posted: Mon Sep 05, 2011 10:33 am Post subject: 89 fender drivers side |
I need a straight fender from an 89 camaro my drivers side is jacked and after the motor swap the camaro is getting a fresh paint job so I need a good one _________________ If you expect a kick to the balls and get a slap to the face its still a victory
jchaussee Member
Posted: Mon Sep 05, 2011 2:45 pm Post subject: |
| I have one you could have, straight exept botton could be hammered out and a little filler, but it get covered by chin spoiler. You can have it if you can get it from renton |
Posted: Tue Oct 11, 2011 1:06 pm Post subject: |
I also have one. Excellent shape, would need paint, $25 it's yours. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
BluFbdy Member
Posted: Tue Oct 11, 2011 3:53 pm Post subject: |
| DBL_TKE wrote: | | I also have one. Excellent shape, would need paint, $25 it's yours. |
sounds like a deal! Im sick of body work ill have to figure out a time to make it down your way, the motor is getting dropped off at bowtie performance tomorrow so ill have to figure out when I can swing across the border _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Oct 11, 2011 5:53 pm Post subject: |
Andy, if you get down there before me, Skyler is holding two pair of aluminum drums for me, could you pick them up for me? _________________ 92 Camaro
BluFbdy Member
Posted: Wed Oct 12, 2011 6:28 pm Post subject: |
Yeah I'm sure I could manage that, as long as it works the other way as well we need to set up Oregon/WA runs for parts exchanges lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sat Nov 12, 2011 4:55 pm Post subject: |
Still got this fender sitting here with your name on it.  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
