Posted: Mon Sep 26, 2011 11:28 am Post subject: Sport Comp Gauges custom for Camaro $450 - W/ Fuel Pressure |
-Autometer Sport Comp Electronic 160mph Speedo
Never worry about speedometer gears or ratio changes again. This is fully programmable and super easy.
-Autometer Sport Comp 8000rpm Tach
-Autometer Sport Comp Volts/Coolant Temp w/ sender/Fuel Level
These gauges are in the panel.
I also have the matching electric oil pressure gauge with sender. It would probably fit in the panel, I just put it in the A-Pillar. Same with the electric Fuel Pressure gauge.
Summit prices on gauges:
ATM-3988 Speedo $219
ATM-3991 Tach $112
ATM-3314 Fuel 0-90 $44
ATM-3391 Volts $44
ATM-3337 Water $52
ATM-3327 Oil PSI $65
ATM-3363 Fuel PSI $200
= $736
Panel is powder coated black. All Gauges are installed and have large weather pack connectors, and on the chassis side I cut the factory wiring back so you can see the colors and sizes to splice into. I wrote out what pin went where and why. Never had any issues with the setup. Turn signal led red bulbs in panel, and one large one for brake.
Yours for $450
That's almost $300 cheaper and the wiring is almost done for you! T56 guys, this is a must! _________________ A redline a day keeps the carbon away!
Last edited by Twilightoptics on Tue Sep 27, 2011 10:01 am; edited 1 time in total |
jchaussee Member
Posted: Mon Sep 26, 2011 6:30 pm Post subject: |
| do you still have that steering wheel pictured?? |
Posted: Mon Sep 26, 2011 6:34 pm Post subject: |
No. _________________ A redline a day keeps the carbon away! |
Posted: Mon Sep 26, 2011 7:56 pm Post subject: |
Pauly why did you have to be a dork and buy the Sport Comps instead of buying the Pro Comps like a normal person? |
Posted: Mon Sep 26, 2011 8:13 pm Post subject: |
Because I liked the white letters of the Sport Comps over orange of the Pro Comp? They both perform exactly the same and have the same bezels..... _________________ A redline a day keeps the carbon away! |
Posted: Mon Sep 26, 2011 8:17 pm Post subject: |
I know they perform the same.
I had Pro Comps in my old car and I really like the white. I'd buy those off you in a heartbeat but I hate black gauges. |
Posted: Mon Sep 26, 2011 8:20 pm Post subject: |
Oh the black face with white digits?
I really liked them at night. I have the red condoms on them and it looks really good and was very easy on the eyes. I perfer the black for that reason. Seems like if it's white face, it's harder to adjust the eyes to and from at night. Let's face it... it's like night here 90% of the time. _________________ A redline a day keeps the carbon away! |
Posted: Mon Sep 26, 2011 8:41 pm Post subject: |
No no, the white face with black digits like so:
http://www.autometer.com/cat_gaugeop.aspx?sid=11
They aren't so hot at night, I'll grant you that. I ran them with just bare bulbs and they were harder to see when dark. |
Posted: Mon Sep 26, 2011 8:51 pm Post subject: |
Ahh yeah. To each their own.
Either way, it's a good deal :O) _________________ A redline a day keeps the carbon away! |
Posted: Mon Sep 26, 2011 9:11 pm Post subject: |
I would be quite tempted for these Paul, but I am saving for something fun. I like stock gauges anyway. Mine are fairly accurate. Rare for stockers. _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Sep 27, 2011 9:39 am Post subject: |
Well Damnit....who DOES want them ? Lol
Edit... I'll give up the matching Oil Pressure and Fuel Pressure (spendy unit) for $100 more! That's $750 in gauges! _________________ A redline a day keeps the carbon away! |
d00012 Member
Posted: Sun Oct 02, 2011 5:29 pm Post subject: |
| I possibly might...won't be soon though...so if you still have them next month, I'll take it. I need to start getting stuff for my Camaro project. |
jchaussee Member
Posted: Tue Oct 25, 2011 2:10 pm Post subject: |
| would you want to sell just oil pressure gauge?? |
flea Member
Posted: Tue Oct 25, 2011 2:16 pm Post subject: |
| Twilightoptics wrote: | | Well Damnit....who DOES want them ? Lol! |
I would but I only have 32 dollars...
Hows that for a blast from the past.  _________________ Killing mailboxes since 2009 |
Posted: Fri Feb 17, 2012 3:17 pm Post subject: |
Edit: Never mind. _________________ 84 Camaro Z28 - LS1/T56
