Posted: Fri Sep 16, 2011 11:46 am Post subject: 82-89' Camaro AC Delete Dash and other 3rd gen parts. |
1) 82-89' Camaro Non-AC dash. Block off plates on D and P sides are molded to the Dash....$30/OBO.
Pick-up only, will not ship. Will deliver within 25mi of Portland, for $10 reimbursement in Gas.
2) 83-02' Factory shifter for T5...$25/OBO
3) Set of RH and LH door handles and locks. I have 1 key for the pair (I'll need to do some searching for it), both match. Detent springs are in good working shape, willing to seperate handles from locks.....$15 w/o locks, $20 w/locks.
4) Miscelaneous resistors and relays and Baro-sensor.....FREE. Will ship @ cost.
Posted: Fri Sep 16, 2011 8:23 pm Post subject: |
Do you have a trunk lock matched to those door locks?
Are you certain that the fourthgen V6 T5 uses the same shifter? I'm not challenging you here, I'm just curious. I had both of them sitting right next to each other in my shop and I'm such an idiot that I forgot to check before I sold one of them. I want to pick up a T5 Pro5.0, but they only list it as 83-92. |
turbo_jimi Member
Posted: Fri Sep 16, 2011 8:45 pm Post subject: |
I've had my Hurst shifter in a 98 V6 and the 85Z...I think the their all the same or at least close enough to work. _________________
Posted: Sat Sep 17, 2011 2:46 am Post subject: |
aaron, they are identically the same shifter. When I put the Hurst in my 86, I took the factory one out of my 4th gen and put the one I had in the 3rd gen in there (because I cut the stick down about 2").
Don't have the hatch lock unfortunately. IIRC when I went to pull it as well, it'd been punched out with a scredriver... |
popballz Member
Posted: Sat Sep 17, 2011 10:39 pm Post subject: |
are those sealed fan relays? my lids pop off easily because i opened them to see how they worked! _________________ -Donald
