Posted: Thu May 09, 2013 4:55 pm Post subject: |
To much,black |
Posted: Thu May 09, 2013 4:57 pm Post subject: |
The engine bay being a different color than the rest of the car is actually more of a MOPAR thing. Aaron's white engine bay has a purpose, as he has stated before, makes it easier to spot leaks and such. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu May 09, 2013 5:35 pm Post subject: |
Leaks from what? The engine is between the white and all the other fluids are easily seen.
Put it together rightb and there are no leaks. _________________ A redline a day keeps the carbon away! |
Posted: Thu May 09, 2013 6:54 pm Post subject: |
Twilightoptics wrote: | Put it together right |
I think we all need to remember who we are talking about here.
Just flipping you crap, buddy. _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu May 09, 2013 7:57 pm Post subject: |
Ford in the 60's did black engine bays. As John mentioned Mopar did off-color engine bays as well.
I did white for visibility while working more than seeing any leaks.
Delta cams are regrinds. I have seen people run them in roller motors without trouble, but who knows. One of the engines I had in the Monterey had one, but that engine blew up due to an unrelated issue. |
Posted: Thu May 09, 2013 9:09 pm Post subject: |
It was free, so I will take to delta to gey specs |
Posted: Thu May 09, 2013 9:11 pm Post subject: |
I made zrto progress todtill ay.,I am jusy,,going to keep temoving parts till I get access to a lift |
Posted: Fri May 10, 2013 4:22 pm Post subject: |
jchaussee wrote: | I made zrto progress todtill ay.,I am jusy,,going to keep temoving parts till I get access to a lift |
Is posting from your phone causing all these spelling errors?! |
Posted: Fri May 10, 2013 4:39 pm Post subject: |
Yes. It is touch screen , cracked and when I try to correct the cursor doesnt gk to right place and then I get frustrated and yell at it. And I have stubby thu.bs |
Posted: Sat May 11, 2013 1:25 pm Post subject: |
Ok. So I am going to clean up wiring a bit. I have deleated AC and jave a AC delete box.
Can I remove the cycling pressure switcbh and wires? |
Posted: Mon May 13, 2013 7:12 pm Post subject: |
Dhe is out. |
Twilightoptics wrote: | White is a bad idea trust the guy who has a white car. It gets nasty fast! |
^^ Truth. |
Posted: Thu May 16, 2013 9:43 am Post subject: |
So it appears I have a 327 block bored ..030 over and I think someone has lut a 350 crank in it because when I measuered with my tape it was closer to 3.5 stroke, but I will comfirm.with a better measuring.devise. |
MrMike98 Member
Posted: Thu May 16, 2013 10:15 am Post subject: |
i think a 327 is just a short stroke 350...same bore
did u check the casting # on the block? |
Posted: Thu May 16, 2013 10:17 am Post subject: |
If you have a 4" bore and a 3.48" stroke it is a 350. It doesn't matter what crank the block had in it originally. The only meaningful displacement-affecting difference between the two is the stroke. _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu May 16, 2013 11:09 am Post subject: |
Then I know have a 350 bored .030 over |
Posted: Thu May 16, 2013 5:14 pm Post subject: |
Lots of 327 blocks had the same casting numbers as 350. It's essentially the same block until you start getting into small journal stuff. _________________ A redline a day keeps the carbon away! |
Posted: Sun May 19, 2013 6:05 pm Post subject: |
jchaussee wrote: | Then I know have a 350 bored .030 over |
355 can be a nice performer! |
Posted: Sun May 19, 2013 6:11 pm Post subject: |
Any displacement can make power. Bear in mind that Al's 383 and Derrick's 305 are within five horses of each other.
Far be it from me to say this, but this build is going too slowly. |
i am exited |
