Edelbrock Fuel Pump 1721
PostPosted: Thu May 02, 2013 8:22 pm    Post subject: Edelbrock Fuel Pump 1721 Reply with quote
Hi. John and I installed this last Saturday in the 85 because the stocker was leaking oil and about to explode. It has no return line. Do I need to vent this? Also, the throttle response seems better. Is that my imagination or can a fuel pump do this? Also, will I need to adjust my AFR on the carb due to the swap? It seems like it drives better but did notice the fuel odor was a little stronger than usual but nothing leaking.
PostPosted: Thu May 02, 2013 8:36 pm    Post subject: Reply with quote
If the old pump wasn't keeping up then you might notice a difference. Shouldn't need to change anything.
PostPosted: Thu May 02, 2013 8:42 pm    Post subject: Reply with quote
Cool!
PostPosted: Fri May 03, 2013 5:28 am    Post subject: Reply with quote
The return line was a vapor lock thing IIRC. I would cap that line well as it is submerged and could theoretically siphon if there were pressure in the tank.
Do you have a normal functioning tank vent?
PostPosted: Fri May 03, 2013 6:06 am    Post subject: Reply with quote
I believe so.
jchaussee
PostPosted: Fri May 03, 2013 1:49 pm    Post subject: Reply with quote
What does normal tank vent entail?
PostPosted: Fri May 03, 2013 8:42 pm    Post subject: Reply with quote
1/4" steel line from top of sending unit to charcoal can underhood.
jchaussee
PostPosted: Sat May 04, 2013 12:08 am    Post subject: Reply with quote
I do not have then. I have a rubber hose on end od that line under my hood that goes to inder car
PostPosted: Sat May 04, 2013 8:56 am    Post subject: Reply with quote
I have the line but not the can.
PostPosted: Sat May 04, 2013 10:34 am    Post subject: Reply with quote
Put a filter on the end of the line.
PostPosted: Sun May 05, 2013 4:25 pm    Post subject: Reply with quote
Which line?
PostPosted: Sun May 05, 2013 6:17 pm    Post subject: Reply with quote
The one that originally went into the charcoal canister. Wink
