You guys seen this happen? Fuel fitting popping off.
PostPosted: Thu May 09, 2013 3:56 pm    Post subject: You guys seen this happen? Fuel fitting popping off. Reply with quote
Found this on TGO. Thought it was interesting enough to share. Start reading at post #8.
http://www.thirdgen.org/techboard/ltx-lsx/673857-power-vette-ls1-filter.html
Did you guys know this already or is it new to you?
PostPosted: Thu May 09, 2013 4:20 pm    Post subject: Reply with quote
Interesting. I hope mine don't pop off, maybe it is incorrect installation? I noticed they don't fit the factory pieces well at all and required extra forcce to "click" on above and beyond what seemed like a good seal when I was putting everything together.
PostPosted: Thu May 09, 2013 7:55 pm    Post subject: Reply with quote
Mine fit like a dream and I have had no issues, but the car hasn't been run much.
PostPosted: Mon May 13, 2013 7:28 pm    Post subject: Reply with quote
Never had an issue with mine and I've put a ton of miles on them.
