Oil pan 305
PostPosted: Wed Mar 20, 2013 5:57 pm    Post subject: Oil pan 305 Reply with quote
Anyone have an oil pan to a chevy small block. Its for my 87 trans am. Pass side dip stick..drivers side drain plug
-Donald
PostPosted: Wed Mar 20, 2013 6:57 pm    Post subject: Reply with quote
I thought I had a couple.
Aaron, did I give them to you to scrap?
PostPosted: Wed Mar 20, 2013 7:38 pm    Post subject: Reply with quote
We took one or two out of your shed for scrap. Don't know if you saved one or not.
PostPosted: Thu Mar 21, 2013 8:24 am    Post subject: Reply with quote
Well, I didn't see them in the shed, so they must be on a ship to who knows where.
PostPosted: Thu Mar 21, 2013 11:10 am    Post subject: Reply with quote
Dang too late. They are not too bad on ebay and summit but idk what the differences are between them all.. do I got a 1 part main or 2 part? (Please Don't shun me for my ignorance)
-Donald
PostPosted: Thu Mar 21, 2013 11:28 am    Post subject: Reply with quote
If your engine is actually an '87, it should have a 1-piece rear main seal.
PostPosted: Thu Mar 21, 2013 7:49 pm    Post subject: Reply with quote
I don't know if it'll matter on the newer pans, but on some of the older ones there were a couple different lengths of the sump. If your exhaust crosses over between the crossmember and the pan sump, you'll need a shorter one.
I found that out the hard way when Paul and I were putting my engine together.
