91camaro_rs Member
Posted: Tue Mar 19, 2013 6:46 pm Post subject: fender well liners |
ok so, my fender well liners dont fit very well it seems like they are too short and ive tried to get em back in and its not going to well, could i use a more flexible plastic and make my own or if i bought new ones would that work better? _________________
Posted: Wed Mar 20, 2013 11:20 am Post subject: |
Fender liners? What are those? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Mar 20, 2013 12:48 pm Post subject: |
DBL_TKE wrote: | Fender liners? What are those? |
I need to take mine out or trim them, they rub pretty badly.
I'm just not a fan of spraying road grime into the fenderwells, hence the trimming. _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Mar 20, 2013 3:43 pm Post subject: |
Alphius wrote: | I'm just not a fan of spraying road grime into the fenderwells, hence the trimming. |
People who take out their fenders are crazy people. I just let mine rub, doesn't bother me. Vulcanized rubber beats ABS plastic. |
Posted: Wed Mar 20, 2013 4:58 pm Post subject: |
Apparently I've been letting mine rub for two years since I lowered it more, so I am right there with you bud!
I actually rub on the frame at full lock since I have an '84 Z28 so it doesn't have the narrow steering stops that the IROC boxes got. I do have the fast ratio though. _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Mar 20, 2013 5:10 pm Post subject: |
Mine actually rubbed worse at stock height. Rubbed a couple holes in it. Since I dropped it the rubbing quit. |
91camaro_rs Member
Posted: Wed Mar 20, 2013 6:53 pm Post subject: |
im not worried about it rubbin cause i already cut out spots for the tire (errr more like just let the tire rub holes in it) but i cant get them to line up for some reason with the holes on the fender i dont know if they shrunk or what, i just need em to fit, could i make new ones out of like dynamat or somthing? _________________
Posted: Thu Mar 21, 2013 6:09 pm Post subject: |
How about mounting to the fender, then drilling new holes in the plastic? I did that on one of mine. |
91camaro_rs Member
Posted: Fri Mar 22, 2013 8:22 am Post subject: |
hmmm thats a good idea ill try that, i also found out today that aftermarket fenders dont allow your GFX to match up right ughhh _________________
Posted: Fri Mar 22, 2013 9:14 am Post subject: |
that was going to be my next thought, is one of the fenders is repo |
91camaro_rs Member
Posted: Fri Mar 22, 2013 5:56 pm Post subject: |
yeah, sucks that i just paid a ton of money for a paint job too, i guess one day when i have a different car to drive for my daily ill get a original fender and get it painted haha _________________
