Posted: Sat Mar 16, 2013 5:59 pm Post subject: Free stuff |
Cleaning out the garage: get it while it's hot, folks!
No holds. I would prefer not to ship unless you're dead set on having some of this crap. Crewbie relay is perfect just as long as you can get it out of here. Pick up in Graham, WA (just south of Tacoma). Whatever is not gone by the end of the week will go to the dump or metal recyclers.
-Camaro tilt column for parts. No wheel, no stalk, no shifter lockout, ignition switch is kinda borked. NO WOBBLE.
-One foot of 2" rubber filler neck hose for yer gas tank
-Bunch of random lengths and diameters of heater hose and probably some low-pressure fuel hose in there as well
-Two locking gas caps for GM vehicles.
-Two Firebird headlight switches
-Metric crapton of 1/2" self-tapping sheet metal screws. Grab a handful!
-Three of four big USA-made clevises
-K&N recharge kit used like twice.
-Unopened pack of Crane moly lube. Yes Crane, like from before they went out of business. No idea of it goes bad, but if it doesn't it can be yours!
-Air filter for late 90's Chevy truck
Posted: Sat Mar 16, 2013 6:38 pm Post subject: |
James would probably like that Alpine unit for his new 'Maro.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
turbo_jimi Member
Posted: Sat Mar 16, 2013 6:39 pm Post subject: |
PM sent _________________
turbo_jimi Member
Posted: Sat Mar 16, 2013 6:43 pm Post subject: |
| RSFreak wrote: | James would probably like that Alpine unit for his new 'Maro.  |
Damn, you read my mind...  _________________
ChrisB Member
Posted: Sat Mar 16, 2013 9:41 pm Post subject: |
I'll take the seatbelt receivers. _________________ 91 Z28 |
Posted: Sun Mar 17, 2013 8:04 pm Post subject: |
if you were closer to me, I'd snag that tilt column off you.
Unless one of you guys up his way wants to grab it, and hold onto it until Dyno for me.
:D |
turbo_jimi Member
Posted: Sun Mar 17, 2013 9:08 pm Post subject: |
I was just over there. I would have grabbed it. Maybe if he brings it to work i can get it then. _________________
turbo_jimi Member
Posted: Tue Mar 19, 2013 9:55 am Post subject: |
| Quasi-Traction wrote: | if you were closer to me, I'd snag that tilt column off you.
Aaron is dropping it off at my house and I'll bring it down. _________________
Posted: Thu Mar 21, 2013 7:41 pm Post subject: |
| Sweet! Thanks James! |
