| turbo_jimi Member
 1985  Chevrolet  Camaro Z/28
				|  Posted: Fri May 03, 2013 4:44 am    Post subject: Edelbrock Fuel Pump 1721 |   |
				| Hi. John and I installed this last Saturday in the 85 because the stocker was leaking oil and about to explode. It has no return line. Do I need to vent this? Also, the throttle response seems better. Is that my imagination or can a fuel pump do this? Also, will I need to adjust my AFR on the carb due to the swap? It seems like it drives better but did notice the fuel odor was a little stronger than usual but nothing leaking. _________________
