TPI Speed Density Engine Harness and extra goodies.
nonsensekid20
PostPosted: Tue Jan 01, 2013 9:18 pm    Post subject: TPI Speed Density Engine Harness and extra goodies. Reply with quote
So I picked up a TPI intake today. Found one with SD plumbing and the correct manifold bolt holes. Runners are a tad dented up but hey, aren't they all? Laughing Now I need a shitload of sensors and the SD engine harness.
What I need:
All sensors needed for TPI except coolant temp for the gauges,
Snorkel Air Intake or ideas for something else (don't want to do the filter in place of the boot since I need cold air instead of hot off the radiator)
SD Engine Harness. Doesn't need the ECM cause I can buy a new one at O'Reilly's.
I believe I'll need an accelerator cable as well.
So far that's all I'm looking for but I'm sure I'll be adding to the list as I go along.
