izcain 9sec Club
Posted: Tue Feb 12, 2013 8:51 pm Post subject: Bunch of parts |
Ok guys just thought I would throw up some random stuff and see if anyone is interested. I have pics and can send them to anyone wanting to see.
1. Chrome Turbo 350 trans pan. Deep pan for about an extra quart or so worth of fluid it looks like. Has some scratches 10 bucks
2. 9 1.2" turbo 350 converter. Stalled to 4500 on the brake but I was able to footbrake 4k on it. Has antiballoon plates and had about 25 hits on it. Would work well for someone. Some of you at the dyno long ago may have remember how the car had instant rpms with this converter. 50 bucks
3. 1986 Chev pickup grill clean no broken tabs. Make offer
4. 82 up non grid tail lights for Camaro. They were hit with VHT nighshades but need to be wiped down real good and cleaned up. Make offer
5. Drag bags (airbags) I made these for a lightweight setup I was running with Z. I was able to 60 foot 1.4's with them but I would not recommend them on the street since they take place of the springs. Come with the mounting tabs and whatnot that i made to make them work nice. Make offer.
6. Moroso windage tray part number 23020 teflon coated . Opened package but never used. It is new. make offer
7. Milodon Rear pan baffle part number 32500. opened but new. Make offer
Also have a clean 383 crank and rod combo but needs a couple of pistons since i think like 2 or 3 of the pistons had some skirt shrinkage but crank and rods are great. Rods are oem shot peened and mag'd with ARP2000 bolts installed. Crank is a external balance scat 9000. Make offer.
Have lots of other stuff but still trying to figure it all out lol _________________
9.17 @ 148
izcain 9sec Club
Posted: Tue Feb 12, 2013 10:04 pm Post subject: |
Also up is a set of 4 rims and tires with 195/50/15 tires. Rims are 4X100mm lug pattern (normal honda/ Acura and lots of others) Tires have like 50-60 percent tread or better.
Make offer time to free up some space! lol _________________
9.17 @ 148 |
Posted: Wed Feb 13, 2013 3:46 am Post subject: |
If nobody local wants the windage tray, I would consider it.
I cant find the 32500 part on summit  |
izcain 9sec Club
Posted: Wed Feb 13, 2013 8:35 am Post subject: |
I messed up the 32500 is a milodon part number..... I will correct it.
pm me your email and ill send you some pics if your interested. I will throw the Milodon part in for free if you want to do something on the windage tray. _________________
9.17 @ 148 |
Posted: Wed Feb 13, 2013 6:46 pm Post subject: |
| So does that just wedge in the pan, and keep the oil from going to the rear? Wonder if that would work on a 4x4 setup? Or would a 4x4 be at that angle to long to make it work? |
izcain 9sec Club
Posted: Wed Feb 13, 2013 7:44 pm Post subject: |
The rear baffle bolts between the main cap and the pump and helps to keep the oil from tracking up the back of the pan when under inclines (wheelies in my case) It wouldn't fit my moroso pan so I never used it. It would prabably work good in a 4x4 with stock pan for keeping oil in the pan and not having it creep up the backside when climbing something! _________________
9.17 @ 148 |
