Seatbelts!
Wulfist
1987 Chevrolet Camaro Berlinetta
PostPosted: Sat Oct 06, 2012 1:12 pm    Post subject: Seatbelts! Reply with quote
Im in the market for some good seat belts that work flawlessly. PM me if you live in the area and want to part with a pair, preferable black but not picky. Thanks!
91camaro_rs
PostPosted: Sat Oct 06, 2012 1:46 pm    Post subject: Reply with quote
i think i still have a full set, its either black that faded to gray or gray, i can check to make sure they all work
Wulfist
PostPosted: Sat Oct 06, 2012 4:43 pm    Post subject: Reply with quote
Sounds amazing, mine are both not locking anymore. The girlfriend won't ride in the car until I fix them =P
PostPosted: Sat Oct 06, 2012 5:25 pm    Post subject: Reply with quote
The receiver doesn't lock or the spool doesn't lock?
I have a set of black front receivers, but no belts.
You are welcome to them if you pick them up.
Wulfist
PostPosted: Sat Oct 06, 2012 5:56 pm    Post subject: Reply with quote
The spool at the roof doesnt lock anymore when you tug on them
PostPosted: Sat Oct 06, 2012 9:29 pm    Post subject: Reply with quote
FWIW, mine don't lock when I pull on them either, they're not supposed to. They lock when the car decelerates and an inertia weight moves and locks the spool.
You can test it with hard braking while leaning forward against the belt.
PostPosted: Wed Oct 24, 2012 4:40 pm    Post subject: Reply with quote
I have the set of the rear (non shoulder) belts in black, but the fronts have since been sold.
