91camaro_rs Member
Posted: Mon Oct 29, 2012 8:39 am Post subject: driveshaft |
so according to the transmission shop my driveshaft is most likely bent so i want to locate one locally just in case i need a new one cause i dont want to pay to have it rebalanced and stuff
i had a u joint fail and drive shaft popped out and tranny puked, hopefully the trans is ok  _________________
turbo_jimi Member
Posted: Mon Oct 29, 2012 11:04 am Post subject: |
I believe i have one in the shed. A little surface rust, but I believe it's good. Used to belong to Gabe. If you want to stop by tonight, it's free. _________________
91camaro_rs Member
Posted: Tue Oct 30, 2012 10:04 am Post subject: |
james can you pm me your number? im not 100% sure i need one cause the tranny shop hasnt called back yet but they almost guranteed id need to have mine reblanced or replaced _________________
Posted: Tue Oct 30, 2012 12:00 pm Post subject: |
The one that James has is from my Z28 and I can assure you it does not need rebalanced and the ujoints were still good when I pulled it out. I only replaced it because I got an LS1 aluminum shaft.
Free is a good deal.  _________________ 84 Camaro Z28 - LS1/T56
