1987_sportcoupe Member
1987 Chevrolet Camaro
Posted: Mon Sep 03, 2012 11:14 am Post subject: quick tranny question |
| Will a T5 from a fourth Gen (V6 obviously) bolt up to my 350 in my 87? |
Posted: Mon Sep 03, 2012 11:33 am Post subject: |
It's been awhile but I seem to remember that it will physically bolt to a V8 bellhousing, so the answer to your question might be yes.
However I suspect that what you meant to ask was "can I use a fourth gen V6 T5 behind an SBC without spending more than the price of a used V8 T5 modifying it" in which case the answer is no.
For further reading see this thread where I unsuccessfully attempt what you're trying to do but backwards (mate thirdgen V8 T5 to fourthgen V6 engine). |
Posted: Mon Sep 03, 2012 1:55 pm Post subject: |
| Ok cool thanks |
Posted: Tue Sep 04, 2012 11:34 am Post subject: |
It will not bolt up. They switched to a Ford style bellhousing/mating flange. _________________ A redline a day keeps the carbon away! |
Posted: Tue Sep 04, 2012 3:15 pm Post subject: |
| Twilightoptics wrote: | | It will not bolt up. They switched to a Ford style bellhousing/mating flange. |
Only the 3.8s. The 3.4s still used the regular junk. _________________
