91camaro_rs Member
Posted: Thu Aug 23, 2012 9:41 pm Post subject: ECM ground locations |
where is the ground for my ECM? my chip just went bad again, that was a brand new one too, i reburned it and ill see if that works but im thinkin i hae a bad ecm ground cause this keeps happening! _________________
Posted: Thu Aug 23, 2012 9:43 pm Post subject: |
| Rear of passenger head IIRC. |
91camaro_rs Member
Posted: Thu Aug 23, 2012 10:51 pm Post subject: |
oh okay ill check that tomorrow _________________
91camaro_rs Member
Posted: Tue Aug 28, 2012 9:43 am Post subject: |
ok so i checked the back of the head and it was fine but where the other grounds are right above that on the firewall, that bolt was all sorts of wiggly loose, so i drilled a new hole and got a new bolt so hopefully that works _________________
fiveoformula Member
Posted: Tue Aug 28, 2012 4:00 pm Post subject: |
| Make sure you are grounding things to a bare metal surface. anything thats painted is not a good ground since paint will act like an insulator. |
