Posted: Sat Jun 16, 2012 7:23 pm Post subject: forth gen parts |
So I bought a bunch of suspention parts off a guy from a forth gen. I am going to use the rear stuff, but I am left with a pair of front eibach sportlines and a front sway bar. The car only had 19k miles so the springs have a lot less. And he thinks the sway bar is spohn but not sure. No sticker. Anyways make an on another note, what rear would a 99 trans am, automatic have? |
Posted: Sat Jun 16, 2012 7:35 pm Post subject: Re: forth gen parts |
jchaussee wrote: | what rear would a 99 trans am, automatic have? |
Ratio? 3.23 probably. Count turns and find out. |
Posted: Sat Jun 16, 2012 7:47 pm Post subject: |
Would you happen to know if posi or not/ guy is also selling rear and tranny . Tranny for like 400 if anybody is interested. Again only 19k miles |
Posted: Sun Jun 17, 2012 9:00 am Post subject: |
1999 should have a Zexel-Torsen limited slip rear end. 3.23 was the "performance" ratio with an auto. It could also be a 2.73. The sticker in the doorjamb with all the RPO codes will have GU2 if it was a 2.73 and GU5 if it was 3.23. G80 on the sticker signifies posi. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Jun 17, 2012 9:23 am Post subject: |
Unfortunately car is no longer around. All the parts were pulled in order to tub it and rebuild front clip. So the guy who did the work just has the parts laying around. I have a feeling he will so cheap that I should just buy it regardless ratio |
