Advice or opinions
jchaussee
PostPosted: Wed Jun 06, 2012 1:20 pm    Post subject: Advice or opinions Reply with quote
So I found a 2000 5.3 that runs but has high miles as in 200k. Also has truck intake and accesories. But price is 300. I have never rebuilt a motor before, but I need to learn. Also would,be a good winter project. My question is , is 300 a decent deal or is that average, or high. ?
PostPosted: Wed Jun 06, 2012 4:04 pm    Post subject: Reply with quote
Does it come with wiring harness and engine controller?
jchaussee
PostPosted: Wed Jun 06, 2012 6:15 pm    Post subject: Reply with quote
No. that was first thing I asked. . If I ran it carbureted for a while, do I still need ecm?
PostPosted: Wed Jun 06, 2012 6:39 pm    Post subject: Reply with quote
ECM and wiring harness is a $300 value by itself.
LS engine doesn't have a distributor so you need something to fire the ignition coils. Running a carb is generally more expensive then using factory fuel injection because of the cost to get the stand-alone ignition system. You're better off staying fuel injected for cost and driveability.
Truck intake is too tall unless you have a large cowl hood. You'll need to install a car intake instead (Camaro / Corvette). Problem is the truck accessories don't work with the car intake so now you'll need different accessories and water pump. And your truck accessories and intake aren't worth much money because most other people need to toss theirs too.
jchaussee
PostPosted: Wed Jun 06, 2012 6:41 pm    Post subject: Reply with quote
So basically Id be in it 600 for a rebuildable motor, plus cost of ls intake. Perhaps ill wait.
PostPosted: Wed Jun 06, 2012 6:45 pm    Post subject: Reply with quote
And you'll need a Camaro oil pan, too. And a trasmission that will bolt to the engine.
jchaussee
PostPosted: Wed Jun 06, 2012 7:31 pm    Post subject: Reply with quote
For tranny,ill go with a t56. Forgot about pan. Also will need to figure out accys
PostPosted: Wed Jun 06, 2012 7:33 pm    Post subject: Reply with quote
Camaro accessories if you want air conditioning. Or you can use Corvette accessories if you don't use air conditioning.
Camaro accessories are out of production and ridiculously expensive used because they fit well in many types of cars. If you see a nice set just buy it or it will be gone when you make up your mind. Water pumps are fairly cheap.
Corvette style can be bought new or used. Needs a special water pump that is extra expensive for some reason. Factor that in to the total price.
PostPosted: Wed Jun 06, 2012 7:40 pm    Post subject: Reply with quote
Title of your thread says, "or opinions" Very Happy
My opinion is stay with traditional small block Chevy unless you have $5,000 or more to throw around. Nothing wrong with a good old Chevy 350, 383, 400.
Wait, back it up here. You're saying that a $600 motor project is too much but you're wanting a $1500 transmission?
What you are buying is essentially a rebuildable core longblock. I would not pay $300 for a core 5.3L, so that is my advice and/or opinion.
jchaussee
PostPosted: Wed Jun 06, 2012 7:48 pm    Post subject: Reply with quote
Id spend 1500 for good motor also. I was wanting a cheap project for winter but after tuping a bit it does seem high for a 200k motor. I plan way in advance, so I would, if I did go the ls route, way untill I got a good deal on a t56. such as someone needing money now, or buying a wrecked z28 or something. I am mever in a hurry so much that ill pay the going rate. Thats why I was asking if the rebuildable ls was a good deal or not.
PostPosted: Wed Jun 06, 2012 7:51 pm    Post subject: Reply with quote
jchaussee wrote:
ls
LM not LS.
Big difference.
Best of luck finding a cheap T56. There are people lined up to pay for those things. No idea why, they break like any other transmission.
PostPosted: Wed Jun 06, 2012 7:59 pm    Post subject: Reply with quote
I've got a broken T56. Laughing
PostPosted: Wed Jun 06, 2012 8:00 pm    Post subject: Reply with quote
I broke mine repeatedly. Laughing
When I sold that car only three gears out of seven worked correctly.
jchaussee
PostPosted: Wed Jun 06, 2012 8:04 pm    Post subject: Reply with quote
Learn something new everyday. I thought only difference was the block material and displacement.so I had to read up. But do the ls hads and mabifold bolt up? And what manual tranny then woukd be better on a semi budget?
PostPosted: Wed Jun 06, 2012 8:07 pm    Post subject: Reply with quote
Block material, displacement, compression; all those seem like pretty big differences to me. Shrug
There is no budget LS transmission. You can put a T5 behind them but I would not think it would last too long in a heavy car like a fully-optioned V8 Camaro.
PostPosted: Wed Jun 06, 2012 8:16 pm    Post subject: Reply with quote
A lot of these 5.3L truck pull outs have automatic transmissions attached to them. Why not just use that transmission? It's cheap and it can be awesome with a good tune and torque converter.
jchaussee
PostPosted: Wed Jun 06, 2012 8:20 pm    Post subject: Reply with quote
I was thonking of it, but unless the wife buys the c5 vette shes been talking about I really think the fun factor of a six speed would be fun.
PostPosted: Wed Jun 06, 2012 8:34 pm    Post subject: Reply with quote
Quit talking people into your old-man transmissions, Jon! Razz
PostPosted: Wed Jun 06, 2012 9:50 pm    Post subject: Reply with quote
Quit talking people in to..... Confused ...... what is it that you're talking him in to anyway? Laughing
jchaussee wrote:
...I really think the fun factor of a six speed would be fun.
I'll tell you what's fun. Watching people in your rearview mirror trying to use a manual transmission in a drag race.
