Wolffy Member
Posted: Sat Jan 22, 2005 4:53 pm Post subject: need help iding 2 sensors |
the first 1 here I think is the cold start 9th injector sensor at the front of the engine
this i have no idea, its on the drivers side & yes Paul its the one that was connected to the dist, now correctly (i hope) connected
thanxs all |
Posted: Sat Jan 22, 2005 10:20 pm Post subject: |
The second one looks exactly like the Coolant temp sensor on the front of the manifold and the Intake Air temp sensor under the plenum. The CTS should've been on the passanger side so maybe the Intake Air sensor? _________________
Posted: Sat Jan 22, 2005 10:33 pm Post subject: |
yeah, top one looks like either MAT or IAT. second one looks like the CTS. |
Posted: Sun Jan 23, 2005 12:58 am Post subject: |
Told you already wolfy. That first one is the 9th injector switch, and the 2nd one is the MAT. If it had coolant on it, it'd be the CTS. Both use the same part number till '89+. |
