		| Author | Message |
		| jchaussee Member
				|  Posted: Thu May 03, 2012 10:04 am    Post subject: Rear end question |   |
				| Looking to buy posi rear out of 91 z28. Gears and teeth appear to be fune but needs new bearings and seals. how much is involved in time , money and skill level to replace them? |  |
		| Back to top |  |
		| turbo_jimi Member
 1985  Chevrolet  Camaro Z/28
				|  Posted: Thu May 03, 2012 11:16 am    Post subject: |   |
				| Call Randy's Ring & Pinion in Everett and ask them how much they would charge and how long it will take then divide the price by 2 and quadruple the time it would take to do it, since you're aren't working on these everyday. This formula seems to work for me.  _________________
		| Back to top |  |
		| Dewey316 The Lama
 1990  Chevrolet  Camaro RS
				|  Posted: Thu May 03, 2012 11:21 am    Post subject: |   |
				| if you are doign the pinion bearing it is also a little more involved. |  |
		| Back to top |  |
		| Alphius Peanut
 1984  Chevrolet  Camaro Z/28
				|  Posted: Thu May 03, 2012 11:24 am    Post subject: |   |
				| I replaced the axle bearings and carrier bearings on a 10-bolt once for IIRC about $50 worth of bearings and about 8 hours total worth of work spread over two days. But that damn rear end fought me every step of the way. Agreed, if doing the pinion bearings too it is much more involved. _________________
		| Back to top |  |
				|  Posted: Thu May 03, 2012 11:27 am    Post subject: |   |
				| Whole diff? What year is your car? 26 or 28 spline axles in your car? The posi  unit you're looking to buy has 28 splines. You need a dial indicator at very least. Also, isn't a '91 diff wide like the 4th gens for the non dished wheels or did they just have deep holes for the lug nuts?
 Which bearings? Axle bearings? Carrier bearings? Pinion bearings? R&R bearings in a diff is one of the more advanced classes.
 Whole rear bearing/seal set will run you over $100.
		| Back to top |  |
		| jchaussee Member
				|  Posted: Thu May 03, 2012 12:29 pm    Post subject: |   |
				| Whole rear with acxles and brakes. Time is not as much of an issue since I have alot more then that then money. It is 50 dollars so I just am curious at worse case acenario as long as gears and axles are good if its worth it. I am sure I can do work if I dont need special tools. and if I buy I reaearch the strps to do it. I just,need to make decision to vuy here soon cause he will bring close to my work. So lets say parts were 100 and I payed 50  then I am in it 150. Seems good. But if parts 300 then ill keep looking. |  |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Thu May 03, 2012 12:31 pm    Post subject: |   |
				| And my,car 85. And I waiting for response to which bearings. But if I swap whike rears I should be fine as far,as anything else right? |  |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Thu May 03, 2012 12:44 pm    Post subject: |   |
				| He,says had,a,slight whine so he woukd assume pinion bearing |  |
		| Back to top |  |
		| turbo_jimi Member
				|  Posted: Thu May 03, 2012 1:42 pm    Post subject: |   |
				| $150 and plenty of time...go for it!
 A whine could also mean bad axles. But axle savers can take care of that.
		| Back to top |  |
				|  Posted: Thu May 03, 2012 2:05 pm    Post subject: |   |
				| Is the 91 rear end assembly wide like a 4th gen? If so you will have your wheels stick out 2" on either side. _________________
		| Back to top |  |
		| Dewey316 The Lama
				|  Posted: Thu May 03, 2012 2:07 pm    Post subject: |   |
				| 91-92 should be the exact same as every other thirdgen. |  |
		| Back to top |  |
				|  Posted: Thu May 03, 2012 3:09 pm    Post subject: |   |
				| I wasn't sure. Because the wheel offset looks different and the 1LE brake option had a different spacing as well. I've seen fourthgen wheels on late thirdgens and they looked normal. _________________
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Thu May 03, 2012 4:42 pm    Post subject: |   |
				| You'll need a press and a bearing seperator. Also as said a dial indicator to set backlash. You'll basically be setting up the rear all over again just as if you were changing gears. Also you most likely will end up with a whine. Used gears have a run in pattern and its hard to get everything set up exactly where it was again. So the gears will be running in a different area and may cause some noise. That won't hurt anything if its set right.. but it could be annoying. |  |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Thu May 03, 2012 5:41 pm    Post subject: |   |
				| The noice will be fime cause I probly wont be able to hear over exhaust. But can the seperating and pressing be done at a machune ship? |  |
		| Back to top |  |
		| QwkTrip 11sec Club
 1989  Pontiac  Firebird
				|  Posted: Thu May 03, 2012 6:18 pm    Post subject: |   |
				| Ya, you might hear that gear whine loud and clear.  The 4.10 gears in my Camaro were flat out loud when cruising and I had extremely loud exhaust.  It's not too much of a bother though if constant high pitch sounds don't annoy you.  Anybody that is married should have no trouble tuning out the noise. |  |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Thu May 03, 2012 6:50 pm    Post subject: |   |
				| Ya. I also have three kids. I can go deaf on command |  |
		| Back to top |  |
 1989  Pontiac  GTA
				|  Posted: Thu May 03, 2012 8:10 pm    Post subject: |   |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Sat May 19, 2012 11:39 am    Post subject: |   |
				| So I decided rear with needing new pknion bearings was beyond my abilities. So now I looking at a 2001 ss rear. He clajms gear ratio is 3.83 but doesnt know if posi. If I can get for 200 is that,a dexent deal? |  |
		| Back to top |  |
				|  Posted: Sat May 19, 2012 5:43 pm    Post subject: |   |
				| could be 3.73 for the gear ratio. Probably not factory gears, I don't think that was an option.
 If its truely from an SS, it should have a Zexel Torsen Posi.
 $200 isn't bad without brakes
 $200 with brakes, is a great deal.
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat May 19, 2012 5:59 pm    Post subject: |   |
				| Offset will be wrong.
 SS with T56 got 3.73 for the last couple years IIRC.
 Price is okay.
		| Back to top |  |
