Need info on what motor is in a '91
rscamaro89
New Member
PostPosted: Mon Jan 26, 2004 11:35 pm    Post subject: Need info on what motor is in a '91 Reply with quote
Well, I think I may have found the car that I am looking for. It is a 91 RS with about 100,000 miles on it. 305, 5spd T-tops... It's got the '92 ground effects on it and 16" wheels. Just wondering if the engine in the car is supposed to be TPI or TBI or Carbourated??? What ever is in it looks brand new, there is like no oil/grime/dirt at all in the engine compartment. Let me know so I can put more thought into before I decide on buying it. I did test drive it and boy, it will be fun to have a V8 Very Happy Gave the sales guy a nice little ride (dude was holding onto the dash board the whole time) Wink
PostPosted: Mon Jan 26, 2004 11:49 pm    Post subject: Reply with quote
What did the top of the engine look like? Was it TPI or TBI?
Was it like a carb setup looking or did it have 8 big silver runners?
Roshambo
PostPosted: Mon Jan 26, 2004 11:50 pm    Post subject: Reply with quote
Well.. if it is stock it would be TBI... visually TPI and TBI are real obvious and they didn't put TPI in the RS cars.
TBI and Carbs use the same style air cleaner assembly but its really easy to tell the difference between the two, just pull the lid to the air cleaner and you should see injectors on a TBI car.
Good luck and hope that helps! Smile
-Joe
1970 Cadillac Sedan DeVille Hardtop - 472/TH400, Air Bags with 10 switches, Memphis Audio.
rscamaro89
New Member
PostPosted: Mon Jan 26, 2004 11:55 pm    Post subject: Reply with quote
Cool, then I wasn't smoking crack... Must be TBI since it was set up pretty much the same was as a Carbed engine. Still a really nice, clean bright red car. Very Happy
What is the posibility/difficulty level to switch to TPI?
EGM: Who's that chick Mario is rescuing up there?
Brian: It's Princess Peach.
Kirk: It's a hooker.
Niko: She looks cut in half.
Tim: Oh wow—she's one of those pole dancers
PostPosted: Tue Jan 27, 2004 4:21 am    Post subject: Reply with quote
the switch isn't bad, but won't gain you anything.
rice B-4
PostPosted: Tue Jan 27, 2004 10:18 am    Post subject: Reply with quote
It's not a LS6, but don't under estimate the TBI.
PostPosted: Tue Jan 27, 2004 10:21 am    Post subject: Reply with quote
Justin, what did you put down? My 305 TPI peanut put down 180HP and 283lb ft. W/ headers and a lean condition.
If TBI IS right in with that, Go TBI.
I am going TBI on my jimmy when I find the parts.
TecherB
Princess B
PostPosted: Tue Jan 27, 2004 12:30 pm    Post subject: Reply with quote
whare did you find the car? (what part of town/dealership)
fine out if you can get any kind of service history on it.
get a car fax on it.
and if you do get it you should check the breaks and pull a valve cover before you think about up-grading anything.
sllt1776
PostPosted: Tue Jan 27, 2004 1:05 pm    Post subject: Reply with quote
well, it is possible to be an RS with TPI. if it has the B4C option. but that's rare. Very Happy
Yup, I'm a traitor but I miss my 3rd gen.
Roshambo
PostPosted: Tue Jan 27, 2004 1:24 pm    Post subject: Reply with quote
Hmm, I didn't think about that... now that would be a find. Smile
-Joe
PostPosted: Tue Jan 27, 2004 1:27 pm    Post subject: Reply with quote
a real find is a 1LE/B4C car or an Original PlayersCup car.
ok, i will stop dreaming....
PostPosted: Tue Jan 27, 2004 1:32 pm    Post subject: Reply with quote
rscamaro89 wrote:
...nice, clean bright red car. Very Happy
Muahahhaaha
My work here is done.
Next?
84transam383
Banned
PostPosted: Tue Jan 27, 2004 7:27 pm    Post subject: Reply with quote
Schultzy89GTA wrote:
Muahahhaaha
Next?
sure
PostPosted: Tue Jan 27, 2004 7:39 pm    Post subject: Reply with quote
Hehe, birdie with Camaro wheels. I thought that was a sin or something. Very Happy
Midnight Sun
PostPosted: Tue Jan 27, 2004 7:44 pm    Post subject: Reply with quote
If it is a sin to look damn good. Then yes it is.
I always though 'maro wheels looked great on birds.
But... biggest I see them is 15inch, and I am way into 17 inchers.
84transam383
Banned
PostPosted: Tue Jan 27, 2004 7:46 pm    Post subject: Reply with quote
shhhhhh! be vewwwy vewwwy quiet,maybe they wont notice Very Happy
there not permanent,there going on my 85 z,i was too lazy to swap off 12 wheels and tires lol,im undecided what kinda wheels are goin on my 84 ..
PostPosted: Tue Jan 27, 2004 8:02 pm    Post subject: Reply with quote
I new I had this pic somewhere, I had to go find it.
The worst ever, 14 inch Firebird SE wheels on an Iroc. Shocked
sllt1776
PostPosted: Tue Jan 27, 2004 8:32 pm    Post subject: Reply with quote
the sin is that it's red.
rscamaro89
New Member
PostPosted: Wed Jan 28, 2004 3:51 pm    Post subject: Reply with quote
At Cars to Go on 82nd and BurnSide
Plan on getting a car fax on any car that I look at
I will try to get the service history
Breaks felt good and thanks for the heads up on pulling the valve cover.
TecherB
Princess B
PostPosted: Thu Jan 29, 2004 12:55 am    Post subject: Reply with quote
for the brake you want to know hoe much you have left on the pads and shoes so you might be able to tell how long until you will need new ones.
when you pull the valve cover you wnt to check for sludre build up how much. plus liik to see in any valve train parts are heavely watn including Valve springs have the been ofer heated and what do their seats looklike.
