redlava Member
Posted: Sun Apr 29, 2012 5:26 am Post subject: Yard watch, 305tpi, t5, 2 pbr rears, and a 91 or 92 bird |
I was at this new junkyard (horseshoe auto wrecking) off belfair highway looking for a tow hitch for the dakota. Of course, i had to check for camaro parts. There was a 88 trans am with what looked like a complete 305tpi, mated to a t5 and a 10 bolt with pbrs (possibly out of a 4th gen should be a 9 bolt for this year). This car also had the trans am tail lights. There was forth gen auto z28(lt1) with a complete rear. I did not check for the engine. There was a 91 or 92 bird with those pieces that go between the front wheel and the front nose. The pass side one was in good shape, the drives side had a small crack about an inch long (looked like it could be repaired).
There were probably 6 third gens that weren't really picked over at all. In fact none of the cars there had really been touched. Seemed like they had good prices. |
BluFbdy Member
Posted: Sun Apr 29, 2012 4:44 pm Post subject: |
thats right around the corner from my house...i feel retarded for not looking there lol looks like im going to go there before work tomorrow and take a peek _________________ If you expect a kick to the balls and get a slap to the face its still a victory
1987_sportcoupe Member
1987 Chevrolet Camaro
Posted: Mon Apr 30, 2012 5:04 pm Post subject: |
While you're there can you find out how much they want for the T5? |
BluFbdy Member
Posted: Mon Apr 30, 2012 5:30 pm Post subject: |
If I'm nor mistaken he said its a fourth gen t5 _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Mon Apr 30, 2012 5:43 pm Post subject: |
BluFbdy wrote: | If I'm nor mistaken he said its a fourth gen t5 |
Reading comprehension!
He thinks the axle is a fourth-gen, not the transmission. |
BluFbdy Member
Posted: Mon Apr 30, 2012 11:14 pm Post subject: |
If I'm . _________________ If you expect a kick to the balls and get a slap to the face its still a victory
redlava Member
Posted: Tue May 01, 2012 7:35 am Post subject: |
There are no V8 T5's in a 4th gen, only t56. The rear axle in the third gen is possibly from a 4th gen becuase it has the pbr rear brakes and a 10 bolt not stock for that car. |
Posted: Tue May 01, 2012 8:17 am Post subject: Re: Yard watch, 305tpi, t5, 2 pbr rears, and a 91 or 92 bird |
redlava wrote: | There was a 88 trans am with what looked like a complete 305tpi, mated to a t5 and a 10 bolt with pbrs (possibly out of a 4th gen should be a 9 bolt for this year). |
4th gen V6 t5s have a ford bolt pattern for the 3800 motor. _________________ A redline a day keeps the carbon away! |
Posted: Tue May 01, 2012 6:30 pm Post subject: |
Well I'm gonna go pick up that tranny either Friday or this weekend. I wonder if they can pull it for me and make my life easier? Hmmm |
Posted: Tue May 01, 2012 7:06 pm Post subject: |
Don't let yard monkeys pull your stuff! They'll leave good parts on the car, bolts won't get saved, things will get broken/stripped/whatever. Do it yourself, do it right. |
Posted: Tue May 01, 2012 9:17 pm Post subject: |
aaron_sK wrote: | Don't let yard monkeys pull your stuff! They'll leave good parts on the car, bolts won't get saved, things will get broken/stripped/whatever. Do it yourself, do it right. |
Particularly the part about bolts not getting saved! You NEED those bolts! _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
redlava Member
Posted: Wed May 02, 2012 10:57 am Post subject: |
I would call before hand, about how to go about the removal of the tranny. Alot of the cars there still had the wheels and tires attached including the trans am with the t5. The cars are not elevated on the T-welded rims. |
BluFbdy Member
Posted: Fri May 04, 2012 9:01 am Post subject: |
I'm on my way down there right now I need a mirror and those dang plastic clips for he hatch plastics, maybe snag a few good extra parts idk _________________ If you expect a kick to the balls and get a slap to the face its still a victory
BluFbdy Member
Posted: Fri May 04, 2012 10:14 am Post subject: |
That old guy at the counter is an extreme prick. They've got 2 great dash pads there though _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri May 04, 2012 10:28 am Post subject: |
...that's the wrecking yard that I gave my '87 formula shell to. _________________
BluFbdy Member
Posted: Fri May 04, 2012 10:41 am Post subject: |
It wouldn't have been black with rims would it? he was just a dick to me for no apparent reason, really enjoys snapping at people apparently. _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri May 04, 2012 8:25 pm Post subject: |
No, red. However, this was probably a decade ago? _________________
