1987_sportcoupe Member
1987 Chevrolet Camaro
Posted: Sun Apr 08, 2012 5:49 pm Post subject: Quest for a reasonably priced T5... |
| So what's the deal with these things? Every V8 T5 I've come acrossed is priced $400 and up, which is way too much for me. Anybody have ideas on where I can find one for $150 or less? |
Posted: Mon Apr 09, 2012 8:45 am Post subject: |
| Unless you find one with broken internals, or someone who took over an estate with a ton of car junk, what you're asking for is not likely to happen. |
BluFbdy Member
Posted: Mon Apr 09, 2012 9:42 am Post subject: |
Man I'm hoping to find a good one for under 600 right now, honestly a rebuild is the most reasonably priced option at this point _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Mon Apr 09, 2012 11:04 am Post subject: |
At my local LKQ, manual transmissions are $135 + core. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
BluFbdy Member
Posted: Mon Apr 09, 2012 11:30 am Post subject: |
Lkq? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Mon Apr 09, 2012 11:39 am Post subject: |
LKQ is a junkyard chain in the PDX area.
Most junkyards have pretty cheap manual transmissions if you get in there before they are gone. _________________ 84 Camaro Z28 - LS1/T56
BluFbdy Member
Posted: Mon Apr 09, 2012 1:57 pm Post subject: |
I need something solid, can't chance this I don't like playing roulette with my drivetrain _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Mon Apr 09, 2012 7:08 pm Post subject: |
| Yea with the junk yard/parts cars they're always gone by time I find them |
Posted: Wed Apr 11, 2012 2:28 pm Post subject: |
| 1987_sportcoupe wrote: | | Yea with the junk yard/parts cars they're always gone by time I find them |
this is usually the case with the V8 T-5's.
That being said, I do have a NWC T-5 I'd be willing to part with for $400. |
