Posted: Wed Apr 11, 2012 4:55 pm Post subject: Exhaust pieces |
If all goes well I should be installing my headers and y-pipe this weekend but I still need a few parts.
- exhaust flanges. I need two sets for 2.5" pipe and one pair for 3" pipe. They can be 2 bolt, 3 bolt, 4 bolt, v-band, band clamp, ball and socket, whatever.
- 3" pipe with 45* bend, just a short section under 2'
- a welder to borrow Most likely not, but my friends welder is not mobile and I'd rather do this on a lift at work _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Apr 11, 2012 6:30 pm Post subject: |
I have a couple extra 2 bolt flanges, and some gaskets for a 3 bolt flange. The 2 bolts are the "ball type". i have some extra miscelaneous exhaust pieces in a box. Want me to bring them to dyno along with the lower boot?
I also have a couple extra exhaust hangers. |
Posted: Wed Apr 11, 2012 9:28 pm Post subject: |
Dyno would be too late, thats my deadline for having the headers on. Lol. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Apr 12, 2012 10:29 am Post subject: |
| PM me your number. I could probably get them to you this weekend sometime if you're free. |
