batcave Member
Posted: Thu Mar 08, 2012 3:39 pm Post subject: im in need of a tpi lower intake 89 |
anyone got a tpi lower intake for my 89 gta l98 just need lower intake if not does 87-90 work thanks |
Posted: Thu Mar 08, 2012 5:07 pm Post subject: |
Didn't they ditch the 9th injector (cold start) in '89? If so, which version do you need, with or without the provision? _________________ A redline a day keeps the carbon away! |
batcave Member
Posted: Thu Mar 08, 2012 11:50 pm Post subject: |
No cold start intake |
Posted: Fri Mar 09, 2012 5:59 am Post subject: |
I'm going off memory here but you should be able to use an early cold-start intake and just not hook the injector up.
What you want to watch out for is the later ('90-'92 IIRC) intakes with the extra runner. You can ask John and James about that one! ![Laughing](images/smiles/icon_lol.gif) |
![](images/avatars/17565934854c4f4e4ab6f09.gif)
Posted: Fri Mar 09, 2012 7:25 am Post subject: |
Quote: | TPI Upper intake, lower intake, runners:
1985-1988 had provisions for a cold start valve. If you are going to use these, you will either need to use a chip for '86-'88 systems, or use a newer ECM/chip combo, and block off cold start system. A fuel rail cap and CS valve plug is available to do so.
1989 was delete of the cold start valve, so the upper intake (plenum), runners, and lower intake do not have provisions for the valve.
1990-1992 was also delete the CS valve, but also had provisions on the Plenum for a MAP sensor bracket above the vacuum nipples on the rear of the Plenum, since '90-'92 was speed density controlled. If you want to use a TPI off of a Corvette, be carefull, the lower intake was made to bolt up to cylinder heads that do not have EGR passages, so you won't be able to use a Corvette intake, unless you want to delete the EGR.
Starting in 1987, the angle of the four center bolts of the intake changed, so if you wan't to use a pre-87 intake on an '87 or later engine (or vice versa) you will have to modify the four center holes to make it bolt up properly. |
Also you could buy one of these if you can only find a pre-'89 intake:
Cold Start Delete Kit _________________ 84 Camaro Z28 - LS1/T56
batcave Member
Posted: Fri Mar 09, 2012 11:51 am Post subject: |
the intake number i need is 10086016 anyone got one for sale im in need of one |
