Full Length headers hedmans 1 5/8
izcain
9sec Club
PostPosted: Sat Mar 03, 2012 8:40 pm    Post subject: Full Length headers hedmans 1 5/8 Reply with quote
If anyone is interested I have a set of Hedmans full length 1 5/8's headers. They were ceramic coated at one time but the coating is coming off and they have some surface rust on the bottoms. They are solid though.
70 bucks
once has a small ding to clear the factory a-arm
a little elbow grease and they would make a nice set for someone.
I can't use them with the new setup
9.17 @ 148
PostPosted: Sun Mar 04, 2012 9:49 am    Post subject: Reply with quote
I had this same set to put in my car once. Couldn't use them. Sad They are pretty quality headers though and fit the car well.
They don't work with a T5. The driver side collector points directly at the slave cylinder and is less than an inch away, so creative exhaust routing wouldn't help.
izcain
9sec Club
PostPosted: Sun Mar 04, 2012 10:32 am    Post subject: Reply with quote
Yea the one thing I found was if you have replaced your motor mounts with polys then the engine sitting up higher makes things interesting with clearance but with a set of S- Bends it took care of it no problem. Thats with an auto though.
9.17 @ 148
1987_sportcoupe
1987 Chevrolet Camaro
PostPosted: Wed Mar 07, 2012 1:28 pm    Post subject: Reply with quote
I'd be all over them if they worked with a T5
coreys90iroc
New Member
1990 Chevrolet Camaro IROC-Z
PostPosted: Mon Mar 12, 2012 11:21 am    Post subject: Reply with quote
i might be interested if you still have them in a few weeks.
1990 Iroc, tpi350 C&C tops. 12/89 build
