Posted: Fri Feb 17, 2012 10:48 pm Post subject: Koni Yellow (Sport) vs. QA1 Double Adjustable |
I cannot find much information on this.
The price disparity between Koni Yellows and QA1 double adjustable struts for the front of my Camaro is negligible. Which would be better? Keep in mind I have already acquired Koni Yellows for the rear of my car, although I see no problem running different struts front and rear.
I know the QA1 is adjustable for both bump and rebound while I believe (but haven't been able to verify) that the Yellows are only single adjustable. _________________ 84 Camaro Z28 - LS1/T56
Posted: Fri Feb 17, 2012 10:56 pm Post subject: |
Do the QA1's have individual adjustment, or does the one adjustment change both compression and rebound?
Unless you can find valving data on the QA1, I would lead towards the Koni, there is a reason it is so popular, and so many auto-xers and racers use them. |
jchaussee Member
Posted: Sat Feb 18, 2012 12:40 pm Post subject: |
I don't know enough about suspension, but I think you answered your own question. If you will be doing a lot of dragging then the qa1, if not then konis |
Posted: Sat Feb 18, 2012 4:04 pm Post subject: |
Thanks, didn't even see that on there.
I still can't decide but I'm leaning towards the Konis still, simply because they're tried and tested and I can't find hardly any people using the QA1 on thirdgens. Plus the amount of adjustment seems confusing. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sat Feb 18, 2012 4:34 pm Post subject: |
Alphius wrote: | Plus the amount of adjustment seems confusing. |
You're not alone with that thought. |
Posted: Sat Feb 18, 2012 6:55 pm Post subject: |
That logic reminds me of one of the reasons i ditched my holley carb. Sometimes more adjustments just enable you to screw things up that much worse! HAHA
~JAKE |
Posted: Sat Feb 18, 2012 6:58 pm Post subject: |
I know it doesn't always work out that way, but I still believe in the KISS method (Keep It Simple, Stupid) _________________ 92 Camaro
Posted: Sat Feb 18, 2012 10:40 pm Post subject: |
The first time I used my Mac computer I thought it was terrible it didn't have all the menus and options. Then I realized it was all entirely unnecessary when something works properly. |
Posted: Sat Feb 18, 2012 11:02 pm Post subject: |
QwkTrip wrote: | The first time I used my Mac computer I thought it was terrible it didn't have all the menus and options. Then I realized it was all entirely unnecessary when something works properly. |
You might even say... well-engineered.
I think I will go with Koni since that was my original plan anyway and I already know they're a hell of a good strut. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Feb 19, 2012 12:05 am Post subject: |
What, no love for AST? _________________
Posted: Sun Feb 19, 2012 12:27 am Post subject: |
iansane wrote: | What, no love for AST? |
Nah. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Feb 19, 2012 10:41 pm Post subject: |
Gabe,
It has been a while since I did price comparisons on the Koni's but this place had one of the best prices I could find at the time. Things may have changed so just use this as another source when you are comparing.
http://www.on-trackperformance.com/koni.htm
Posted: Mon Feb 20, 2012 12:03 am Post subject: |
Thank you Mike, have you ordered from them? Their price seems too low to be believable, so I am inclined to be wary. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Feb 20, 2012 8:08 am Post subject: |
I have not ordered from them.
jchaussee Member
Posted: Mon Feb 20, 2012 10:23 am Post subject: |
Holy molybdenum. That's cheap. |
Posted: Mon Feb 20, 2012 11:02 am Post subject: |
Seems like a decent price to me. _________________ A redline a day keeps the carbon away! |
Posted: Mon Feb 20, 2012 11:06 am Post subject: |
That's $370 for two. The cheapest I've been able to find anywhere else is $545 for two.
I'm thinking based on the website design that that price may be quite old. I might call them and confirm it when I'm ready to order. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Feb 20, 2012 11:15 am Post subject: |
Alphius wrote: | Thank you Mike, have you ordered from them? Their price seems too low to be believable, so I am inclined to be wary. |
Wow, that is very cheap. I found another reliable source for rear Koni SA shocks (or so I've read on TGO) for $100 each but I haven't seen anywhere that less that $240 a piece for the front struts. I might just place an order soon. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
