Posted: Fri Feb 17, 2012 10:53 pm Post subject: Brake line |
| Need the soft line from chassis to rear axle. Will hit the yard tomorrow so hit me up quick if you have one locally. |
Posted: Sat Feb 18, 2012 12:26 am Post subject: |
I might have the one that came with my LS1 package. Didn't use any of the rubber lines since I had them made locally out of stainless braid. I'll take a look in the morning. _________________ 92 Camaro
Posted: Sat Feb 18, 2012 9:37 am Post subject: |
| I have two of them, each with the brass tee crimped one end. IIRC, the two are different - one is from my 83 axle and has an SAE fitting on it, the other came with the LS1 kit and has a metric fitting. |
Posted: Sat Feb 18, 2012 12:18 pm Post subject: |
| The brass-tee style is exactly what I need, and I need the metric. You gonna be around today? |
Posted: Sat Feb 18, 2012 12:38 pm Post subject: |
No plans yet...
You may need to run a thread chaser into the fitting, it's a little corroded from sitting around - even in a zip-lock bag. |
Posted: Sat Feb 18, 2012 1:02 pm Post subject: |
| I might roll out that way today, Al. I'm eager to pressurize the system and see how the new flares and fittings hold up. |
Posted: Sat Feb 18, 2012 1:05 pm Post subject: |
| Sure, just give me a call first before you roll out, just in case I might need to run errands. You do have my number?? |
