head swap questions
jchaussee
PostPosted: Fri Feb 03, 2012 7:52 pm    Post subject: head swap questions Reply with quote
So I am getting ready to swap heads. I have ever done before. I have done head gaskets about 11 years ago on my 84 Chevy. Anyways first. Gaskets. Do I just buy a top end gasket kit from a machine shop or autozone? Second. Pushrod and rocker arms. How do I determine which ones to get? Third. Machine work. They are low Mile used heads so what should I have machine shop look at and what work should I have done? And finally what other areas should I address when ivhave heads off?
PostPosted: Fri Feb 03, 2012 8:13 pm    Post subject: Reply with quote
What heads are you going from and to? If you are sticking with the stock cam, and using GM heads, I would bet chances are good that your pushrods won't need to be changed, but you will want to check the alignment of the rockers on the valve stem once you get it together.
I think it would be wise to have a machine shop give the new heads a once over. It could save you a lot of frustration later. Make sure they aren't cracked, warped or otherwise damaged.
You'll need everything just like changing out head gaskets. Top end gaskets, along with new head gaskets.
Some of the questions will be more able to give answers to once you give us more info about what you current setup is, and what the new heads are.
Its always helpfull to give as much information as you can on questions like this.
jchaussee
PostPosted: Fri Feb 03, 2012 8:20 pm    Post subject: Reply with quote
Sorry. I forgot to give head info. The heads a currently have are the 882 heads. My new heads are called pro topline srt's. They have 167cc runners. 64cc combustion chambers and are 1.94/1.60s. They have screwvin studs and guide plates. I don't know what cam I have and they are going onto my carberated 327
jchaussee
PostPosted: Fri Feb 03, 2012 8:22 pm    Post subject: Reply with quote
Sorry. 67cc chambers. These heads
http://www.flatlanderracing.com/heads_protork.html
PostPosted: Fri Feb 03, 2012 8:33 pm    Post subject: Reply with quote
Don't take this the wrong way....please.
You need to find out what cam, also, what pistons are in the 327, are the 67cc heads even going to give you meaningful compression? Also, what springs are you using, do these springs work with the cam/lifter combo being used? For gaskets, what gasket size has the intake runners been machined to? Does your intake match this, or will there be an issue there?
Are you pistons at zero deck, or how far in the hole are they? You will need to know this to pick the right head gaskets.
What hardware is included with those heads, studs? Also, I want to think that someone on our board used a pair of these, and had problems with the installed studs and had to go to ARP studs.
Before you really take this all on, you want to make sure you get all of this stuff sorted, or you won't be happy at all with the results.
jchaussee
PostPosted: Fri Feb 03, 2012 9:23 pm    Post subject: Reply with quote
Great. Seems like I need the answers to questions that I don't know how to figure out.
PostPosted: Fri Feb 03, 2012 9:27 pm    Post subject: Reply with quote
well, you need to do some reasearch into what you have, that is for sure.
Its part of the learning process, I spent more hours than I can count asking people questions like this to learn, it is HOW you learn. But, you do need to do some research for yourself, and we'll help you figure out what will work.
jchaussee
And as far as compression. Is smaller the chambers, higher the compression?
PostPosted: Fri Feb 03, 2012 9:28 pm    Post subject: Reply with quote
Yes, but pistons also come in different sizes, that will effect compression also.
PostPosted: Fri Feb 03, 2012 11:05 pm    Post subject: Reply with quote
The old pros had crap for studs. I put in arps after breaking them quickly.
jchaussee
PostPosted: Sat Feb 04, 2012 2:56 pm    Post subject: Reply with quote
Ya. Ill probably have to hold off for a while. I may not be ready for such a grand undertaking. Iit would end up taking me monthes it sounds like.
jchaussee
PostPosted: Wed Feb 15, 2012 10:48 am    Post subject: Reply with quote
So Paul. Besides studs breaking, what did you think of heads. Were you happy with them?? I am sure they will be an improvement over what I have. I just want to make sure it will be worth the time its going g to take me. I still have a lot of learning to do. Lime how to figure out which cam to use, and such but it is what it is.
MrMike98
PostPosted: Wed Feb 15, 2012 11:13 am    Post subject: Reply with quote
I believe that you will also need Hardened push rods for use with the quide plates,
so you must also figure out push rod length to keep geometry proper..
M
jchaussee
PostPosted: Wed Feb 15, 2012 11:39 am    Post subject: Reply with quote
Ya. I am still doing my research on how to figure all that out. I am new to this and have never done before. It will still be awhile till I start because I need to buy my pieces as money permits and I want to have everything ready so hopefully it can be done in a weekend. I have been reading about cam selection and it seems to be quite a science
PostPosted: Wed Feb 15, 2012 12:13 pm    Post subject: Reply with quote
Need hardened pushrods for the guideplates, and you need to measure to get the right length with a pushrod length checker.
Heads were awesome for cheap power, but mine were 200cc not 180 so I can't vouch at all.
Mine at 2.02/1.60 valves, the guides were weak and the seats were weak. The valves didn't seal that well for long.
jchaussee
PostPosted: Wed Feb 15, 2012 1:07 pm    Post subject: Reply with quote
So can some of these issues you addressed br taken care of by a machine shop?
PostPosted: Wed Feb 15, 2012 1:10 pm    Post subject: Reply with quote
Yeah, you can have new guides installed. Or spend even more money and have better seats installed and the valves redone.
You're talking $400+
jchaussee
PostPosted: Wed Feb 15, 2012 1:19 pm    Post subject: Reply with quote
Never mind in that. We will just see how long they last.
jchaussee
PostPosted: Fri Feb 17, 2012 1:59 pm    Post subject: Reply with quote
So I was talking to a guy about my head swap. And he is telling me if I don't rebuild bottom end, it will fail soon after I put on different heads. Is there any truth to that and should I be concerned.
PostPosted: Fri Feb 17, 2012 2:17 pm    Post subject: Reply with quote
Bottom end life is based on age and materials.
300 wheel horse is about the limit for a sbc without mods.
They guy is talking out of his ass.
