For Sale: 1986 RS, $3500
PostPosted: Fri Jan 20, 2012 8:12 pm    Post subject: For Sale: 1986 RS, $3500 Reply with quote
Well, I think its time to say farewell. It's not that I want to get rid of it, I just don't drive it and I would rather see someone else enjoy it than have it sit and rot. Beefy is a project car but not much of anything is needed to drive it. And I have tons of random stuff that comes with it that no craigslister would need. I'm not going to part it out. I have a title and I can drive it anywhere. So please, let me know if you are interested.
For Sale
1986 Chevrolet Camaro RS.
The vehicle is primered black with omni sealer primer, tinted windows at 30%, has keyless entry with alarm, and 4th gen front cloth seats. The car is a runner, complete, and straight aside from there are no rear seats or back plastic for spare tire cover. All normal vehicle functions work including power door locks, power windows, power rear hatch, rear defroster, dome lights, int wipers, headlights, map lights, heater, power steering, but not the cruise control and no e-brake. The car has no rust, inside or out.
This car has been altered and does not have a stock option powertrain. Below is a list of modifications.
Chassis:
H4 headlight conversion
Clear front markers
Clear side markers
Stock rear lights
Good Carquest battery
Weight: 3300 lbs
Suspension:
4th gen Camaro front brakes, 12x1.25”, 2 piston calipers
Custom front spindles
Boxed A-arms with poly-urethane bushings
34mm front hollow sway bar with full urethane bushings
Wonderbar brace
500inlb front springs
Lowered 3” front
Chevy 9-bolt rear axle, 3.42 ratio
10” rear disk brakes, iron calipers
Boxed lower control arms with urethane bushings
Boxed panhard bar with urethane bushings
Torque arm relocated to transmission mount
125/175 progressive rear springs
24mm rear solid sway bar with full urethane bushings
Lowered 2” rear
C5 corvette wagon wheels, 17x8
Powertrain:
Stock V8 radiator
1978 454 cuin, 7.4L Chevrolet big block
‘049 heads
Edelbrock Performer Air-Gap intake
Holley 750 CFM double pumper mech secondaries, no choke
Summit Street Scoop
Stock valve train
HEI distributor, magnetic pickup, vacuum advance
Electric fan
Electric fuel pump
Keith Black fuel regulator
Dyno’ed 260hp 360ftlbs at the wheel with stock smog cam
Turbo 400 transmission, non-overdrive, Kevlar bands, shift kit, kick down disabled
Tranny cooler, 10x14
Home built tranny cross member
Homebuilt headers with 3” dumps and 3.5” straight exhaust, rear exiting
Extra Parts included:
Chevy 10-bolt, 26 spline, 11.5” aluminum PBR brakes, 4.11 gear, auburn limited slip
Chevy 10-bolt, 26 spline, no brakes, 3.42 gear, welded carrier
Random sway bars, front and rear
Random springs, front and rear
Chrome high rise valve covers
Additionally for sale is a set of 18x9.5 C5 wagon wheels with BFGoodrich R1 tires, 275/45R18, $800
Vehicle starts and runs every time. The car is loud, low, very fun to drive, and handles fairly well. It has been autocrossed, it has been drifted, it has not been drag raced. This has been my project car for the past 8 years so I know a lot about it. I am selling it to learn something new and let someone else enjoy it. I have put a hundred miles on it in the past 2 years but start it up every other weekend to warm it up.
I am asking $3500 for everything listed. If you feel it's worth less and you are interested, we can talk about it. I would love to sell it to someone in the crew so I can keep tabs on it. Thank you.
PostPosted: Fri Jan 20, 2012 8:15 pm    Post subject: Reply with quote
Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
(I might just delete you post to make you keep it)
PostPosted: Fri Jan 20, 2012 8:24 pm    Post subject: Reply with quote
Ya, I know. I just don't have the time to keep going with it. I'm going to keep playing with it until someone wants it, of course. And I have a ton of cool parts that goes with it.
PostPosted: Fri Jan 20, 2012 8:28 pm    Post subject: Reply with quote
pfff, just huck a 6spd behind it, and you'll drive it more.
PostPosted: Fri Jan 20, 2012 8:31 pm    Post subject: Reply with quote
I'm with stupid
Although I'd be thinking more like a four speed and a lower rear gear because I can appreciate needing to outline a project that actually might get done someday. Embarassed
PostPosted: Fri Jan 20, 2012 8:33 pm    Post subject: Reply with quote
That's the other bit, money. The next step for the car would be to spend some serious money. T56, new slugs, 9" swap, cage... and all for something I don't have the time to play with.
PostPosted: Fri Jan 20, 2012 9:30 pm    Post subject: Re: For Sale: 1986 RS, $3500 Reply with quote
That is a sinister looking car. Somebody is really going to enjoy it.
And what would that be? Very Happy
PostPosted: Fri Jan 20, 2012 9:31 pm    Post subject: Reply with quote
I'm with stupid
I think a jerico or something similar would go much better than a t56 with the "theme" or "style" this car has. This car is seriously cool. Sad to see it go.
PostPosted: Fri Jan 20, 2012 10:31 pm    Post subject: Reply with quote
I hope it doesn't "go". I'd love to see someone scoop it up and stay around. I think the price is reasonable with all the stuff that comes with it. If someone wants the non-bolted on parts just speak up.
jchaussee
PostPosted: Sat Jan 21, 2012 2:46 pm    Post subject: Reply with quote
I am going to try and sell mine so I can buy yours
91camaro_rs
PostPosted: Sun Jan 22, 2012 1:24 pm    Post subject: Reply with quote
if i had 3500 i would buy it in a heartbeat...
PostPosted: Wed Feb 29, 2012 9:34 am    Post subject: Reply with quote
Price is getting cheaper, around $3000. If anyone wants any of the spare parts listed above, i will be making a run to bremerton at the end of next week and can meet up with whomever. I have a collection of front and rear springs, sway bars, and random grey interior parts.
Hielor
PostPosted: Wed Feb 29, 2012 2:19 pm    Post subject: Reply with quote
If the rear end with brakes is still available, that definitely sounds like something I'd be interested in.
PostPosted: Thu Mar 01, 2012 9:13 am    Post subject: Reply with quote
I might have the rear sold. The disclaimer on it is it is a 26 spline 3 series case with a 2 series carrier, 3 series gear, with an adapter. In other words, it wont hold up to the abuse of a small block.
Hielor
PostPosted: Thu Mar 01, 2012 9:47 am    Post subject: Reply with quote
Awww, guess not then, although I just have the stock 305 with no plans for changes soon...
I was hoping that would turn out to be a good way to both move away from drums and get a better ratio, but if it won't work that's irrelevant.
Thanks anyway!
PostPosted: Thu Mar 01, 2012 1:58 pm    Post subject: Reply with quote
Drum to disk is an easy conversion. I think it took me a couple hours last time. Also, I have a 28 spline auburn if you have the axles.
Hielor
PostPosted: Thu Mar 01, 2012 3:21 pm    Post subject: Reply with quote
For the brake swap, I've heard that it's often easier to just grab an entire rear end...
As to the diff, since I've got a 91, assuming I've got the stock axles they should be 28-spline. What's the gear ratio? I did have it mentioned to me that it looked like my diff had been making metal at some point
PostPosted: Thu Mar 01, 2012 4:28 pm    Post subject: Reply with quote
It is just the carrier. No gears on it. I have never ran or taken it apart so I don't know the condition of the cones.
PostPosted: Thu Mar 01, 2012 6:41 pm    Post subject: Reply with quote
http://www.dailymotion.com/blue89rs#video=x9ug3b
Vid of the car. For those who are interested. I have a few other video's in there of more random stuff.
PostPosted: Thu Mar 01, 2012 7:33 pm    Post subject: Reply with quote
Fishtails easy enough. Very Happy
