tv cable for carberared cae
jchaussee
PostPosted: Sun Feb 12, 2012 11:42 am    Post subject: tv cable for carberared cae Reply with quote
While I can get a dorman product from what I have read it is better to get a good used original then a new dorman
PostPosted: Sun Feb 12, 2012 12:01 pm    Post subject: Reply with quote
If you don't have the proper Computer Controlled Quadrajet and cable for it...
And you have an old Q-Jet, Holley, or Edelbrock carb.....
Then you HAVE to get the bracket setup from Bowtie Overdrives.
http://www.bowtieoverdrives.com/index.shtml
Otherwise you'll burn up your 700R4.
Period.
No questions.
No what ifs.
No "I have this and it works now."
YOU WILL BURN UP THE TRANS WITH ANY OTHER SETUP.
jchaussee
PostPosted: Sun Feb 12, 2012 12:08 pm    Post subject: Reply with quote
I have a non CC quadrajet, so wouldn't the cable and bracket off a factory Carb car work?
PostPosted: Sun Feb 12, 2012 12:18 pm    Post subject: Reply with quote
Period.
No questions.
No what ifs.
jchaussee
PostPosted: Sun Feb 12, 2012 12:21 pm    Post subject: Reply with quote
I read what you wrote and I have been to that site. I am just wondering why then a factory set up minus the computer part of the Carb wouldn't work?
PostPosted: Sun Feb 12, 2012 12:33 pm    Post subject: Reply with quote
Most of the earlier quadrajets do not have the transmission peg in the correct spot. Get it wrong and you will burn up the transmission.
The correction brackets that holley and edlebrock sells are not correct either. Been down that road myself. I finally bought the bowtie kit for my holley. After that the transmission shifted perfectly.
jchaussee
PostPosted: Sun Feb 12, 2012 12:54 pm    Post subject: Reply with quote
My Carb is an 85 non CC Carb. That's why I am wondering why wouldn't work
PostPosted: Sun Feb 12, 2012 1:03 pm    Post subject: Reply with quote
There's tons of info on bowties website about where the peg is supposed to be. If it is correct then you're fine.
