vibrations
Goto page 1, 2, 3  Next
91camaro_rs
PostPosted: Wed Feb 01, 2012 12:37 am    Post subject: vibrations Reply with quote
today i noticed my car started vibrating a lot i can feel it in the steering wheel, it wasnt like this yesterday, and at idle at a stop if i turn the wheel it vibrates a lot not only can i feel it in the wheel but the whole car shakes, i have power steering fluid, my alignment is way off, and my tires are bald, but why would it start all of the sudden? bad PS pump maybe?
PostPosted: Wed Feb 01, 2012 3:48 am    Post subject: Reply with quote
If your tires are bald, they could have started seperating and/or creating air bubbles.
You could have also had a weight fall off.
BluFbdy
PostPosted: Wed Feb 01, 2012 5:18 pm    Post subject: Re: vibrations Reply with quote
If its shaking at a stand still i dont think weights have anything to do with it, it may be that a weight got tossed but youd never notice at a light, i say have someone turn your wheel while you check under the hood and go from there
idk any symptoms of a bad pump until it blows
PostPosted: Wed Feb 01, 2012 5:23 pm    Post subject: Re: vibrations Reply with quote
In order to shake something needs to be moving. The way I figure it there is only one thing moving when you're at a stop that is part of the steering system. Wink
PostPosted: Wed Feb 01, 2012 5:25 pm    Post subject: Reply with quote
Ops, didnt notice that that phrase in it. Once again, bit by responding first thing in the morning.
Could it be the crack in the frame ordeal that the wonderbar is suppose to fix?
BluFbdy
PostPosted: Wed Feb 01, 2012 5:35 pm    Post subject: Reply with quote
Oh yeah I forgot a T rex took a bite out of his frame.... you think the welds snapped?
91camaro_rs
PostPosted: Wed Feb 01, 2012 6:07 pm    Post subject: Reply with quote
what welds??
and i do have a wonderbar
BluFbdy
PostPosted: Wed Feb 01, 2012 6:16 pm    Post subject: Reply with quote
The guy who did your sfc's did a patch job on your frame didn't he?
jchaussee
PostPosted: Wed Feb 01, 2012 6:52 pm    Post subject: Reply with quote
Perhaps a bad u joint?
PostPosted: Wed Feb 01, 2012 7:51 pm    Post subject: Reply with quote
U-joint is stationary at idle...
jchaussee
PostPosted: Wed Feb 01, 2012 8:00 pm    Post subject: Reply with quote
My bad. I kindof skimmed it. I would assume a bad mount such as motor or something. Hard to imagine whole car shaking with a bad pump.
91camaro_rs
PostPosted: Wed Feb 01, 2012 11:47 pm    Post subject: Reply with quote
i get new tires on monday, so im gonna have em mounted balenced and an alignment we'll see what happens then and go from there
PostPosted: Thu Feb 02, 2012 6:29 pm    Post subject: Reply with quote
If they find a family of raccoons living inside your old tires that would explain why the tires vibrate just standing still on the ground. If not, then you probably need to keep searching for the problem.
PostPosted: Thu Feb 02, 2012 7:36 pm    Post subject: Reply with quote
Tell the tire shop to be careful. Dizzy raccoons tend to exhibit a negative attitude.
Killing mailboxes since 2009
IROCDave
PostPosted: Fri Feb 03, 2012 5:20 pm    Post subject: Reply with quote
Do you have headers? If yes, how close are they to the steering shaft?
91camaro_rs
PostPosted: Sat Feb 04, 2012 12:56 pm    Post subject: Reply with quote
i do have headers and im not sure i can go measure
PostPosted: Sat Feb 04, 2012 7:43 pm    Post subject: Reply with quote
This entire topic is one gigantic facepalm.
Luke posts up that he is leaking PS fluid, then post that the engine bogs when the PS pump is loaded (i.e. wheel turned at a stop) at get the following suggestions:
Bald tires
Cracked frame
U-joint
Motor mount
Family of racoons
Headers
These are all terrible suggestions brought on by people who cannot add one and two together. So I will help them do so.
PS pump is lubricated and cooled by it's own fluid
It had less than the proper amount of fluid
It died
Now it doesn't work
This is not rocket science, it is shade tree mechanics. I am a lousy drunken Polack carpenter and I can see through it. Come on!
PostPosted: Sat Feb 04, 2012 7:57 pm    Post subject: Reply with quote
You're going to be embarrassed when they find raccoons.
Damnit Aaron. Come down to Benders in Renton and watch my band and be drunken with music.
10706 SE Carr Rd Renton, WA 98055-5826
No cover. We play at 930.
You can point out the obvious there too. ;0)
jchaussee
PostPosted: Sat Feb 04, 2012 7:59 pm    Post subject: Reply with quote
Where did he post that?
Page 1 of 3
