Drivers door
algershick
PostPosted: Mon Feb 06, 2012 8:08 pm    Post subject: Drivers door Reply with quote
I've got an '86 drivers door that is actually in VERY good condition. Its a power door with a power window, mirror, and door lock. The glass isn't too bad, with some really fine scratches in it.
The bad news is the upper door hinge itself has had its bushing holes welded closed then redrilled to attempt to fit a smaller diameter bushing in place. What I'm getting at is the door side of the hinge needs to be replaced.
$20 takes it, otherwise I'm going to chunk it in the dumpster.
1988 GTA, 5.3/T56 in the works.
