power steering pump or just the hoses
91camaro_rs
PostPosted: Wed Feb 01, 2012 1:20 am    Post subject: power steering pump or just the hoses Reply with quote
my power steering hoses leak so i need some new ones that dont, i have a 350 tpi with serpentine
if you have a whole pump with both hoses that would be better
PostPosted: Wed Feb 01, 2012 9:36 am    Post subject: Reply with quote
Mine leaks too. The high pressure hose (the one with the crimped fitting at the steering box) is like $25 at NAPA.
You might check to see if the O-rings on the hoses are worn out.
Red92Bird
New Member
1992 Pontiac Firebird
PostPosted: Wed Apr 25, 2012 6:11 pm    Post subject: Reply with quote
If you are still looking for the powersteering pump and hoses i have them. from a 91 firebird.. make offer
92 Bird l03, 700R4, 10 bolt 3.42 eaton posi. 275/40/17's
91camaro_rs
PostPosted: Thu Apr 26, 2012 8:46 am    Post subject: Reply with quote
yeah im still in need of one, dont have a lot of cash at the moment so once i get paid next week ill check back in with ya
PostPosted: Thu Apr 26, 2012 9:32 am    Post subject: Reply with quote
I just bought a PS hose kit for like $20 at O'reilly.
Red92Bird
New Member
PostPosted: Thu Apr 26, 2012 11:01 am    Post subject: Reply with quote
I need it outta here so lemme know what you can do. $20 sound ok??
91camaro_rs
PostPosted: Thu Apr 26, 2012 7:25 pm    Post subject: Reply with quote
$20 is fine, does it leak or anything?
Red92Bird
New Member
PostPosted: Fri Apr 27, 2012 12:04 am    Post subject: Reply with quote
i dont remember seeing anything. however i will check it out tomorrow in the daylight and make sure everything is in good shape. its still hooked up so it will be easy to see any leaks.
