EGR Digital control issues!?!?!...
sheltonw3
PostPosted: Sat Dec 31, 2011 7:13 pm    Post subject: EGR Digital control issues!?!?!... Reply with quote
last night I was out with a friend in his car a 91' 3.1 and the car dropped power and stalled out and there was no service engine soon light and prior to this we had the hood open and noticed during warm up the EGR valve shot a couple of sparks and surge up a bit and it smoothed itself out and ran nice and then 30 minutes later across town it dies and to make matters worse the EGR works with the ECM and we had no heat for 3 hours waiting for the slowest ever tow truck to pick us up!...
so right now we both have no money til later in the month and I am wondering if the digital EGR can be reconditioned or does it have to be replaced with a new one??
I checked all fuses and they are all good, no burned fusible links, the alternator is still fairly new, the car cranks but no turn over and no S.E.S.!
thanks in advance!
Its not a question of how fast can it go?...its a question of how fast do you wish it to go?
PostPosted: Sat Dec 31, 2011 7:33 pm    Post subject: Reply with quote
Should run with an SES light on.. if you just unplug it. Otherwise there's some other issue, or it has caused another problem.
PostPosted: Sat Dec 31, 2011 7:37 pm    Post subject: Reply with quote
Does the SES light blink very briefly and then stay lit with KOEO?
Has the car been sitting for awhile? Or sitting outside in the rain?
sheltonw3
PostPosted: Sat Dec 31, 2011 9:42 pm    Post subject: Reply with quote
We get no light at all and it was a daily driver for years until recently and it has been raining recently more and the car does stay out , no garage!
sheltonw3
PostPosted: Sat Dec 31, 2011 9:46 pm    Post subject: Reply with quote
According to my shop manuals the EGR runs with the ECM and it states that if the EGR craps out the ECM will shut down!...so when I turn the key no SES, I don't hear the fuel pump priming , the securty light goes off , I turn the key and it cranks but no turn over.
PostPosted: Sat Dec 31, 2011 10:23 pm    Post subject: Reply with quote
sheltonw3 wrote:
my shop manual ... states that if the EGR craps out the ECM will shut down
Come again? Laughing
Did you check the fuse in the clip next to the battery?
sheltonw3
PostPosted: Sat Dec 31, 2011 10:38 pm    Post subject: Reply with quote
Too late now and toooo cold , gotta wait til tomorrow to look.
PostPosted: Sun Jan 01, 2012 12:47 am    Post subject: Reply with quote
I replaced the connector on mine a few years back and mis-clocked it (I have that same EGR on my V6). The car ran fine, just threw the EGR code because the pintles didn't open as commanded by the ECM. Luckily, the way I had it connected didn't hurt the EGR itself.
sheltonw3
PostPosted: Sun Jan 01, 2012 2:51 am    Post subject: Reply with quote
Like I said the SES light is not coming on at all!... the car cranks ,but no turn over, I am starting to wonder if the ECM just took a dump instead?...won't know til tomorrow and Might try disconecting the battery and waiting a mintue and see if there is any change there.
PostPosted: Sun Jan 01, 2012 9:01 am    Post subject: Reply with quote
I ran my 3.1 with NO EGR at all, wasnt even bolted in.
Something else is wrong. fuel pump, coils, something. But egr will not keep it from running unless its cracked so bad its creating a vac leak of bibilical perportions.(lots of spell check in that line)
PostPosted: Sun Jan 01, 2012 9:06 am    Post subject: Reply with quote
Just a thought. Try removing the O2 sensor and see if you can get it to run. I had a plugged up cat once, and instead of killing the motor, the pressure blew the EGR riser right off the manifold. Never did throw a code. Removing the O2 sensor should give exhaust somewhere to go if the cat got plugged. Replacing a cat doesn't cost as much as that EGR.
PostPosted: Sun Jan 01, 2012 9:49 am    Post subject: Reply with quote
Laughing
C'mon you guys, the ECM isn't triggering the fuel pump relay or the CEL. That means it's fried or it's not getting power. He can unplug and test sh*t till he's blue in the face and it won't help anything.
PostPosted: Sun Jan 01, 2012 12:23 pm    Post subject: Reply with quote
I was just trying to demonstrate to him that its not the EGR valve lol. When someone gets something in their mind, sometimes they wont listen til they see it cant be for themselves.
PostPosted: Sun Jan 01, 2012 12:26 pm    Post subject: Reply with quote
I got ya, B. My comment was more directed at the vacuum leak and O2 suggestions. Not that those are wrong but he's got bigger issues. Cool
BluFbdy
PostPosted: Mon Jan 02, 2012 9:30 am    Post subject: Reply with quote
Is it possible the bulb is burnt out? I'd check that before hunting down a new ecm lol
PostPosted: Mon Jan 02, 2012 11:12 am    Post subject: Reply with quote
I'm with stupid
Definitely need to check these thing. Easy enough too. Check light should come on when you first turn the key on. If it doesn't, it's burnt out or there is an issue with the ECM be it it's dead or missing power/ground. If you hook up JUST the ecm to power/ground/SES light the ses light will come on indicating the ecm is functioning.
BluFbdy
PostPosted: Mon Jan 02, 2012 2:34 pm    Post subject: Reply with quote
Whoaaaa how does that make me stupid? Regardless of function a bulb is still a bulb lol I'm personally a fan of going from easiest to hardest when it comes to fixing something or you can just throw parts at it lol
PostPosted: Mon Jan 02, 2012 3:03 pm    Post subject: Reply with quote
That smiley just says he agrees with you Cool
BluFbdy
PostPosted: Mon Jan 02, 2012 3:16 pm    Post subject: Reply with quote
Its very deceiving lol
PostPosted: Mon Jan 02, 2012 3:21 pm    Post subject: Reply with quote
One more thing with that simple idea. I'm not sure how you checked fuses, but if you just looked at them then please check them again with a test light or meter. Many times a fuse will not appear to be burnt but is. A test light is an easy way to check.. just touch both the small metal patches on the back of the fuse.. if the light lights on both.. all is good.
